		dt125r-  how to bleed cooling system?
		I think theres some confusion here oliver wants to bleed air from the 'airlocked system' oliver just take of the rad cap and give the pipes a few pumping squeezes...that should do it
		How often should I change my oil?
		once a year or 6000 miles would do it for me...or go off the manual
		TDR125 overheating help?
		The head gasket is leaking, thats what's wrong! You should stop riding it or risk warping your cylinder head! Buy a genuine yamaha one...pattern ones cant be trusted IMO...been there and got the T shirt
		dt 175 no spark.
		original plea for help 9th july, original poster not been on since 9th july...bad manners in the least .....pahhhh!!!!!
		2010 XJ6n fan not working questions...
		Thanks for the update cupcake...one to warch for in future eh?
		Is there a warning when the oil pump fails?
		Ultimately the biggest warning you'll get is engine seizure...yikes Best to fit a clear tube between the pump output and the carb and any air bubbles present in this tube should be investigated Also the seals can dislodge or start to leak...If the pump drive seal leaks badly your gearbox oil level will be increased by the leaking 2T oil The pump piston also has a small seal and if that one is leaking you will see 2T oil in the pump compartment The pump should be bled though do you know the bleeding procedure? Personnally I'm a big fan of these pumps myself...far better than premix IMO so why do you thing your pump is failing?
		XT has died
		whats the deal here, why not just fit a new seal ?
		dt 125 re a couple of niggles any ideas unsafe
		yeah the oil light is for the 2 troke oil, you put that in the tank not the engine!...you're causing confusion now for sure
		you can just take out the drain screw, drain it into a clean container and refit the screw when the level has dropped no need to fully drain it. Use the oil in the container to add some if you overdo the draining. isnt there a 'window in the case for the oil level? if there is the oil should be half way in the window with the bike upright.
		1980 Yamaha mx 100 dual purpose conversion.
		I'm no expert but I dont see why not.
		wrong answer my friend, you need to check the oil level and do something about it if it's over filled
		you dont fill it until it's pretty full, you fill it to the correct level, havent you got a manual or owners book to refer to? Over filling could be the cause of the issues you are having!
		DT 125 r 2007 wheels&tyres
		or you could just fit someroad biased tyres to the existing wheels (avon distanza?)
		They did make this bike in supermoto form, it's the DT125X so look out for wheels and forks for one of these bikes...NEV will tell you more if he sees this post
		greetings from Donegal
		Greetings shiner
		Did anyone do something interesting today
		just looked in here for the first time, curiosity got the better of me y'know...just wanted to see how the rest of ya did interesting stuff WOW BLACKHAT !!!
		In the midst of purchasing a 2003 WR250F, just a few questions.
		That looks great John, it's tall isnt it no chainguard whatsoever?
		I think he's referring to a 12v digital speedo Jason?
		Hello everybody,
		Greetings Jörg
		Not a DT175E Rebuild
		theres something wrong...something not fitted right...kicker axle, did you put the kicker return spring into its correct hole...ie NOT the adjacent casing screw hole?
		Thats not the case ( no pun intended) I have never had to use sealer and have therefore been able to re-use the same gasket many times over...you must have a lump on one of the mating surfaces
		Pretty sure that the bent bit of the clip goes into that square hole in the case
		xvs 125 starting problem
		another easy check is try it without the airfilter in to eliminate a dirty clogged filter
		Hello
		greeneggsand ham lol, wow that takes me back a heck of a long time to when I was in junior school in the 60's, a great book as i remember Greetings and
		Weekend in Cornwall
		Crikey bip thats a heck of a trip for just a weekend, Great report it made for some interesting and amusing reading I went to Cleveleys and back...that was a long way for me lol. BTW did you trade the YBR in for the big T ?
