Kevin S
Everything posted by Kevin S
  1. Kevin S posted a topic in Naked
    Can someone with a similar bike ,tell me what color the wires are for the connection at the gas tank , for the gas gauge? I have no wires there now (tank) and want to hook something up. I see a green connector not being used hanging off the frame near the underside of the tank. I'm wondering if these are the wires? Kevin
  2. Kevin S replied to Kevin S's topic in Naked
    Thanks for the info.. Kevin
  3. Kevin S replied to Kevin S's topic in Naked
    Anyone have any ideas??? Also would the valves being a little on the tight side of spec, give me stumbled or poor low speed acceleration? Kevin
  4. Kevin S posted a topic in Naked
    Hello guys My little brother has an 87 FZ600 and I took it apart over the winter to fix it up a bit. What would be the pilot screw settings for these carburetors? The manual says either "preset" or "2.5 turns out" depending on which model. I'm not sure which model it is. When I removed the screws from each carb, I documented the settings but they can't be right. They were 3,2.5,4 and 5 turns out.The bike had very stumbled low speed acceleration , but speed up a bit and it takes off like a rocket. What do you guys think I should set the pilot screws at? Kevin
