yamazingr1
Everything posted by yamazingr1
  1. Thanks for searching on this one, really appreciated - looks like its pointing towards the battery. Been on optimate all the time, but battery now 5 years old so i have probably done quite well so far. Its not happening all the time so i guess i can live with it for now.
  2. I dont see any error codes as its starting or stalling, or is there a way to display the error codes after the event ? There are no mods to the bike at all - totally 100% standard as out of the crate Had the bike from new its only done 5k Any help appreciated
  3. Seeking some help with a problem with my R1 2007 4C8 From cold bike starts, runs fine all the time. Normally drive to petrol station 0.3m form home, fill up then go to start, the bike fires up but dies straight away, yellow engine light comes on at the point just before it cuts out Will only stay fired up if revved above 3k ish. Happens with side stand down or up, in gear or not in gear. I have tried putting stand up and down in case it’s the sensor, switching ignition on & off to reset system, in gear rocked the bike to see if this helps, but none of these cure it. Once started and driven off the bike doesn’t die when coming to junctions, so the fault is only on starting at this point when the bike has just travelled a short distance so is only just warm. Any help appreciated or anyone else suffered the same problem & knows the fix. Thanks in advance
  4. http://www.flickr.com/photos/24570840@N03/2326214373/
