- Xs400
		Rejet for pods and exhaust
		Anybody know what size the pilot jets are on a 1980 XS400? I got it to run more consistently after replacing the faulty coil so I'm looking to place my order soon. Oh and the carbs don't have the movable clip on the needles its the 79 that does.
- My Mess
- Points cover
		Points cover
		Nevermind I'm a dumba$$ ... figured it out a couple minutes later. 1980 has no points But I tested the coil and the secondary winding failed the test. So now I have to find a coil.
		Points cover
		I think I figured out why my bike was running ok then not running at all. The left side is loosing spark. I tried to pull the points cover but the rear screw has some kind of plug in it? This is on a 1980 XS400. My other bike a 1979 has a screw in each hole. I tried picking around it to pop it out but it doesn't move. Its not rubber either. I guess I could try drilling a small hole and getting a screw in it to pop it out. Any ideas?
		drewpy - You mean change the location of the clip? Do I move it towards the tip of the needle more or back towards the top of the diaphragm? I think now the clips are on the 3rd ring back from the tip of the needle. xs360 - The pods I bought say they are for 1980 XS400s but they were too small to fit over the carbs but fit perfectly on the intake tubes. So I didn't really gain any extra space. I think the mains are 132.5 stock right but what are the pilots? I was thinking about the Part #07-0041 taper tip mufflers from www.mikesxs.com to replace my blown out stock cans.
		I was out on a test ride yesterday and the bike started bogging and barely kept running. I checked the plugs and they are both black which I figure makes sense since the airfilters have been soaked with fuel many times. So I pull the filters out and run again. Much better. But I check the plugs again and I'm lean of course. I have a set of pod filters to put on and I want to replace the stock mufflers. Any thoughts on how many sizes to go up? Maybe 2 sizes to start?
		Help - Idle screws broken off
		Thanks XS I'll try that tomorrow. In my haste I tried pushing the tips back up through with a screwdriver but only managed to break them off flush with the carb passage. I'll see what happens.
		So I'm tearing down the carbs on my 79 and I notice the tips of the idle mixture screws stayed in the carb when I removed them. Well that explains why they never made any difference when it was running but now what do I do? I tried pressing on the tips from the inside to push them back out but that didn't help. Any ideas or am I stuck finding another set of carbs? Maybe I could just drill them out but I have no idea what size the hole is in the carb or if I have a bit that small.
		XS400 - Top End
		Did the ball bearing in the clutch fall out maybe? Or you could try running through the adjustment procedure again.
		1980 XS400 - I got screwed again
		Wow drewpy that silver bike is awesome Thanks for the pic.
		I usually run at least 89 octane in my bikes since that has additives in it unlike the junk 87. I guess I'll order carb kits too since my old bowl gaskets are a little leaky anyways. Here's a pic of the beast when I brought it home if anybody is interested.
		Thanks for your help guys Whats everybody running for oil as far as weight and brand? I bought some new carb holders last night so hopefully that cures my surging and racing at idle but if not its time to blow apart the carbs again.
		I doubt I could be so lucky. Any ideas on the oil out the exhaust? Oh and has anybody ordered from that http://www.partsnmore.com/ place? They seem to have the best price on airfilters I've seen. Also the XS650 carb holders are the same as the 400 aren't they? Mikesxs.com has a set for the BS34 carbs but they are a different yamaha part number between the 400 and 650 but they sure look the same. Any idea?
k91
				Joined
					Last visited
_33963e.png)
    _83bc35.png)
