eire_kp61
Everything posted by eire_kp61
  1. hi there, Ive read through a couple of forums about the 3xv and its restriction to 45hp Im also aware that de-restriction is next to impossible .... or is this true ? can anyone talk from experience about this , maby theres 3xv owners here ?? id also be interested in talking about tuning. ive heard the sp model is full power ? ive located a full 1993 sp wiring loom and coils and generator ecu etc ( ecu part number 3xv-70 ) maby this would bring it up to full power cheers in advance chris 1993 3xv owner
  2. if your battery is definatly fully charged then it sounds to me like you got a bad earth or loose connection because if you have full charge in your battery the horn would work your starter problem is down to the same bad connection id say
  3. hi there lads, Im in the process of fully rebuilding my 1996 tzr 125rr 4fl can anyone here tell me if the sachs xtc125 engine is identical to the tzr, i know its the same engine but is the wiring the same ? are the cylinders the same ? and finally are the gear ratios the same ? i know there is some differences between the tzr dtr and dt125r and all use the same engine, i think some had chrome cylinder lining and some didnt etc also i think the dt has short gear ratios can anyone help out with this as ive located a xtc with a sweet engine ps sorry my fist post is info seeking chris
