pufferfish_88
Supporter
  1. hi, to keep this short and sweet, my tw125 (same engine as an sr125) has become quite noisey and clicky, somebody btold me this is probably the cams or timing chain being loose and slapping about, great, but how do i tighten it, cant find the info any where and please bear in mind im a bit of a retard so carefull explaination would be much appreciated
  2. hi had the exact same problem witjh mine. the battery was fine all that needed doing was the starter plunger of the choke needed replacing(i.e. the little meatal bit that goes in the carberetor) as it had worn down and awas not sucking fuel through as it didnt have a strong enough vaccum, so it just sucked air. try it i know how arkward it is .
  3. hi. im new here, on this forum anyway. ive had a yamaha tw125 for about 6 months and its great but im going to give it to my girlfriend and get a tzr125 as i hear they are a veryfast and cheap 125. however the 1 i am getting is the '88 model and has not got the full ypvs on it, i understand you can put one on but what do i need to get and how do i put it on and what difference does it make anyway. any other info about the tzr will also be much appreciated. thanks. jak
