blackhat250
  1. Follow your heart O/J, as you"l always lust after the cbr if you buy the virago, Its only £800 , if you don't like it ebay it. Hondas are reliable. too
  2. Hi eden " great intro, put up a picky then ,
  3. blackhat250 replied to drewpy's topic in Projects
    That looks so neat ,,, and expensive
  4. Here , see the small hole at bottom of choke well, blast it thru with carb cleaner, .it may need rodding , ,fuel must pass thru, to fill the well, for choke to work ,
  5. Hi lavmax, yeh its the choke lever, witch if fed by a brass pipe that's dips in to a well in the carb bowl, thers a small hole feeds the well .make shure its clear, as cynic says , get full flow from tank first, pull the pipe to see flow.
  6. Up and down simon ? not side to side , my kwaker triple did this on middle cylinder , rattled like hell, well its a crank big end for you then, Grampian eng [ Liverpool ] will supply and fit .
  7. Is it a nakarsil bore ? these can be coated back to standard size, google is best friend here , find company to price it,,
  8. Hi linz " Andrew elivis fan is the SR 125 GURU, hes had em to bits,,
  9. Put a cover over the tank, and wash all paintwork wen finished,
  10. Hi ray" dropped,[fell over] or crashed ?
  11. You and kev sharing the same tent ? your making the same noises ,,,
  12. Well bugger me, out on sunday, found this place ,,,360mils over the weekend on DT,
  13. Welcome scott", have you not a 125 to run till you can ride the Draggy, cbt - then ? D/A. or mod 2
  14. Typical one hit wonder " posted 6am - looks back in @ 8am, nae answer , so hes off
  15. Hi glen", thers a few TT owners in here, post up your question in workshop section,
  16. Hi glov" yeh plenty help in here,
  17. Bens lookn swell, Is your nephew a builder, [ ]
  18. FKn ell" , how long ago were they fitted ? [ new that is]
  19. Hi steve " you"l need a dating cert for proof of age, OR, the original Title [ usa log book] , insure it on the frame number,
  20. Yeh, but theres a newish Zed 1000. goes past too.
  21. Right am back " 300 quid lighter, , Dam usb port broke[ mouse '& keyboard fob] froze screen = pulled the power cable, and crash, , tried to start pc, some page saying USB fault - then closed down,,,So new desktop, its better anyway,, Aye kev , I know Yorkshire like the back of me hand, ,,, I only get lost following you lot,,,
  22. Welcome in Jeff. Post up some pics.
  23. Oi" kev. Am a explorer Remember the first year. We did our own thing. My computers down Had to log in through f.b
  24. Yeh , jeff " try dropping the front sprocket 1 tooth, it will pull the higher gears to red line,
