blackhat250
  1. welcome in Jackal " ..
  2. Welcome, dan ...the Xv boys will be along with answers ,
  3. It looks warm , but it war freezing, by the time we got home, it felt like this,
  4. SB200- cd175- Triumph1050 - BMW-800, on the north sea . Todd hill lighthouse,
  5. Hi there, you lot are Backward .
  6. Welcome aboard dave , " .. 3 is good,
  7. Hi carlos " good wee bikes them , hardy. thers a few owners in here, . although its been quiet in here lately.
  8. blackhat250 replied to Vulture's topic in Projects
    Yeh , good progress, handy that your skilled with the lathe ,
  9. Hi Bri " ,,
  10. Hi vulture". that's a good selection of bikes, plenty XS help in here,
  11. Your a party Animal finerez...
  12. Too hard to describe,, take pics of your bits " ,, and post on here, bike bits that is,,
  13. Hi JJ" ,good to see your back on 2 Wheels,,
  14. Yeh , there cheap, , you"l need a tool to hold flywheel to undo nut,. I use a filter chain. , then the puller has left hand thread, then bolt thru middle pushes against crank end, .. Yours is a dt250mx, and has a mono shock, [ one]. like my DT250D , .here,
  15. Yeh , basically the same as my 1976 SET-UP. , starter ? it needs a relay- soliniod-
  16. You need a meter, switched to Ohms, see what the pulser coils [ on stator,] are putting out, also ,disconnect ALL connections to CDI, AND CLEAN ,, corrosion will be the cheapest fix , CDI" rarely go wrong,
  17. Welcome in ". similar too you, I had the Garelli , then a DT175C, in white/red, in the hottest summer 1976, . the fuel tank was black with corn lice, that year, . who said global warming, .bollocks was warmer then ,
  18. Hi sky" , Tw125 , 180 wide rear tyre, ... goofy little bike,
  19. Its usually a imperial size, 3.00 = 3 inch wide, 3.50 = 3 and a half. I run a 4.00 x18 on rear of DT250, 275x 21 on front, see not 2.75. . manufactures differ , and a 180x 55x 17 is 180mm. Wide 55mm profile,and 17 inch rim,, clear aint it
  20. Right , av just done my DT 400 & 250, THE 250 WAS POINTS, its now CDI, the crutial circuit to make it run, is the power from soarse coil, [ red/white- brown - black ] these plug into the corisponding 3 prong plug, on CDI .[ COLOURS MAY differ, slightly], now out the other side of CDI. THERE IS Orange- to coil, black/white,- ignition switch, black- earth,. that should get you running, the yellow & white are lights, [ off other coil] lightimg,
  21. Well " they"re getting big money noo, http://www.ebay.co.uk/itm/331772807461?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
  22. Hi Damien " yeh great bikes , heres the Rossi rep .
  23. Hi arron " heres another helpful site, http://yamahadtclub.proboards.com/
  24. Belated welcome,,,,
