- Summer bikers
- My Bike
Dragstar 1100 backfiring
When you said it was charging. did you put the meter on, ? and what voltage showed, shudda been at least 13.8volts, . and maybe the battery is the main culprit, , it shude be a stable 12.6. ,then keep meter on it, press starter , if its goosed it will drop to around 9v
TDM900
hI LEM ". its like a story from the 1970"s
XTZ660 1992
- 6v idiot light bulbs to led
Just checked, 21w, in the now, ordered 18w, can you get lower ?- 6v idiot light bulbs to led
While"s on the subject .my bllinkers are rapido. [ dt400] , how can I slow them, . up resistance ?- Intermittent ignition short CT2 yamaha 175 enduro
1 hit WONDER,,,,,,,,,,,,,,,,,,,,,,,,,- I've just joined!
Hi gabe " what 125 are you thinkin about ,?- Anyone remember Caftf red light jumper?
Just seen this, Capt.F, it should read ,,, great show.- New To Yamaha Owners Club
Welcome in Kiwi"- '99 DT125 R swapping front rim for 18" help
Yeh , they"l need to measure your rim etc ,for spokes, google wheel builder. thers plenty ,- Power loss when warm!
Aye dave " its illimination process . swap the coil, then points/ condencer, how does it idle when warm ?- New member saying hi.
Hi craig "- High altitude jetting...carbs, not planes...
Hi Richard " good to see you back ,- Intermittent ignition short CT2 yamaha 175 enduro
Yeh , condencer , sumthing simple, or the coil breaking up once hot, . basic illumination process, ie cheapest component first, . pug/ cap/ coil/ points -condencer,- Xt125 1984 project
Hi stevo ". been busy I see,- RD350LC decals
Ha kev " is the Mellow yellow no more, back to standard ?- Help
Replace them, there cheap as chips, . get the right size.- 1968 YAS1C - started!
This bikes a twin aint it " if its fokked crank seals, the right hand pot will foul if sucking gear oil, this pipe will smoke more, and stinks, the left seal will suck air,[ generator side] and the idle creeps up as the engine warms,- Dt125re reztoratio.
Just seen this, your cracking on ,, good effort .- Newbie from Perth, Scotland
Hi scott. am 35 mls north of you. . the worst job IMO. on a 4 cylinder ,is carb /cables removal and refit , I hated that job,- Hello
Welcome in stace " ,,,yeh there a track bike favourite nowadays- Chief Scouts Commendation
We werna allowed to join the BB"s or scouts, [ being R,C, ] It was all so wrong back then ,,- Slightly bent handlebars
Yeh toutsie", a good metal worker will have a press, . I took a gate to blacksmith [it was like a banana] I said make me a new one, he said I"l straighten it, well bugger me ,its like new, - 6v idiot light bulbs to led
