blackhat250
  1. Yeh the 924 was the poor mans porche , a 4 cylinder wern"t it,, 928 looked good with a 6 pot,,,,
  2. Hello Patrick " top o" the morning to yeh" ,,,,,as my dear old ma used to say,,,,,,
  3. Aha, i get the N.O.S bit now,, . yeh 2008, thats when i joined too, i"v been to kawks a Suzi"s , still Yams in the blood tho,, stick around,, as Forums are in decline,, that facebook is the cause, ,
  4. Deffo Drewps... Perth- Blairgowrie A93 - Then up the scenic Glenshee - to Braemar - then on to Tomintoul , brilliant road, ,then to Grantown on spey.. from there, you have a choice - back over to the A9 [ only 15miles to inverness left on that bastard road,] .or, to Aviemore, then under the A9,,,,[ staying on b class roads, to Lagan ,[ spectacular views] to Spean Bridge, then a choice, north to Skye or south to Fort william,. take a right to Malaig [ ferry to Skye ] £7.00 for a bike, .then over the island , then over the bridge to mainland again, then north to Apple Cross,, this is back on the NC500,,,, heres us Halfway up the cattle pass, to applecross, , amazing,,
  5. hI, CHRIS,,,,,,, ,lincoln got good team at the moment,
  6. I put the tank in, and said ,same as the last time. [ he did black 2 years ago]. the tank was a yellow one, i had rubbed down , and there was a trace of yellow underneath, So by the time he got round to it, he seen the yellow , and just presumed [ mother of all FKups], he made a great job,,, I still got the yellow, am gonna do it Orange, like theDT250C,
  7. There seams to be more action on here lately, Hows about our meet this year, since Squires is wearing thin, , i"d say, about mid summer, and then you can still do Squires, if you want, ., discuss,
  8. It was Yeller last year tommo, , i built one for my mate, and the painter,, painted the tanks yellow instead of black, So i took the black off my bike and put it on mates, i ended up wi the yellow,, that bugger is the black tank i gave away was a minter, no dents or rust,, most are toast now, [40years old], i stll have the yellow, [ i have a plan for it, ;
  9. Hi Ian " , i wonder why it ended up in boxes,,,,,,,,,,,,,,,Jimmy,,,,,,,,,,,
  10. How come paul,,, its not Pissbucket - its Imgur
  11. Cheers paul,, a lot of flattening, and filling small dips, still to be clearcoated .... . then wet sand [ 2000 grit], and pollish with compound,,
  12. After the painter boobed last year [ yellow] i thought i"d give it a go, ,, bought a 250 tank, pulled out the big dent with a valve glued to it , filled /primer/ base & decals.
  13. wELCOME IN, ! wont be long,,,, daffodils are shooting up,,, .. [ yeh with crack] ,,,,,
  14. Hi brando, a detent spring purpose ,,is to hold somthing in place, , maybe the choke lever, what type of carbs ?
  15. Tommy ten bikes is the XT guru, [ not been on here in ages]. the bike will be leaning over ,as the stand hole will be enlarged,- bolt worn, or the bracket thats welded to frame bent,,,,with short arses starting it on the Stand,
  16. Thats a lot of bike for the cash,,,,good buy,,
  17. Also, my M,O,T tester, stuck a deflector tape on lens . to pass,, .. you can get 5inch new lence, or 5"1/5 . whatever it is,, UK spec.
  18. Hi " did it work then ,,?
  19. Ffs" dont do that, you"l faint at the Rear wheel BHP figures---------------------------
  20. Mind in the 1970"s ,we were all about 8-10 stone,,,,, these same bikes are running with pillion now,============,
  21. What weight are you Chris ? ,,
  22. Sounds like the YZ80 MOTOR, mind Gaz67 [ fizzy special yz80] ,, at squires,, total blew big cruisers away, on race to cafe , on new years day,,, The guys said " since your on Little Un " you lead the way, got to cafe ,and the guys were miles behind,
  23. Tommo" on a ride last year to Campbeltown , i on the RD400 mate on the Triumph Steet675. both fueling at same time, i used 9 litres to his 11litres, worked out at 58mpg,,, , shocker, eh, slow riding sort shifting, on the way home, [faster] i dropped well below him,,
  24. Ok, the pilot circuit & choke circuit are working,. did you says it starts without choke ?.[ cold ] ..and its looking for more,AIR, ?, SOUNDS LIKE YOUR CHOKE washer, is passing,, un screw it,, its the pullout type,, take alook at rubber on bottom,, Hey digger,,,,,, join here,, http://yamahadtclub.proboards.com/
