Posts
8,343 -
Joined
Last visited
Days Won
192
Content Type
Profiles
Gallery
Yamaha Racing News.
Media Demo
Store
Collections
Classifieds
Clean all the connections, ,check battery voltage too
Hi tim,, pop up some pics,,
Standard of driving is woefull,,,,,see it every day, they dont look at junctions, txting , & fone glued to thier ears,,,,
Hi max" ,the CDI"s [OEM] are ok, am running the original , i had the Rex speedshop settup. and it failed , [ its him that says the old cdi"s are crap] , i told him it failed ,and his only reply- "weve done an upgraded version" ,so i said trade the old one against one,= No reply, So, back to the carb,,change the jet setter,[immulsion tube] and needle, as if they are worn ,more fuel get sucked thru ,. what colour was the plug ? ,,, Read this. see what i mean , https://yamaha-enduros.com/index.php/forum/performance-improvements/7305-rex-s-electronic-ignitions
Hi martin ,, did you over oil the filtre ?... , what colour is the Plug,?, next time she splutters, shove the choke on ,[ just to see if its fuel starvation ], if its worse with choke ON, ,then shes neEding AIR,
info required on barn find yamaha
blackhat250 replied to Lee Celtic's topic in Dual Sport, Offroad Bikes
Hi lee, Am surprized a YZ has a battery, they usually start on a magnito system, The value will be on demand, and ebay is the shopwindow nowadays, -
Hi ed" , great wee bikes them 700"s......keep their value too, /?
We had no rain for months, and you"s managed to find some,,? , .its bonnie up there if suns out, https://imgur.com/wj2GAp2 https://imgur.com/wj2GAp2
Last of the twinshock model, 1G1- 1977/78 ,, should be silver /white fenders, The 1976 = 559- Red with white stripe,[ Nayruff avitar].
Welcome in Windy ," post up pictures ,, not familiar with this model ,
Question about importing a YZF-R 125 from Europe to UK
blackhat250 replied to cowanpete's topic in The Bar
Speedometer is not part of the M.O.T., And your headlight beam can be altered by using a bit of tape in the right place, . -
Thru the week is best,, the weekend warriors from the citys are out on the roads at weekends, ?
aye- up ...
sOUNDS LIKE FLOAT LEVEL, , i would also remove the float valve , and clear the passage
.. inn,,,,,,,,,,,,,,,,
Hi there, you sound like ur from the states, great vintage enduro following over there,
Bealach na Bà, is awfull in wet, esp if foggy, i have only seen the top once in 3 trips to Apple-x, , thers a small ferry at Corran ,5 mins and your over to Ardnamuchin ,peninsula from there you can do Isle of mull [ 20mins ferry] , or loop right round to Glenfinnan, viaduct and loch , ,
Hi AULD EEN ". that sachs be german eh, they made chainsaws etc, Sachs-Dolmar,,,
Hiya Bip",, its been awhile,, forcast crap this weekend,, typical eh,,,,
. Inn.....................
Yeh even the twinshock is different from the Mono-shock, as the cable enters the cases in different location, i HAVE a N,O.S bottom half [] both cables ] for the twinshock DT400, but am not using it, its worth more in the bag, ?
Read this post ,, no deffinate lenth yet,,, am rumnning a Dt175mx cable, https://yamaha-enduros.com/index.php/forum/1977-forward/8295-1978-dt400-oil-pump-cable-lenght?start=0
Points model i take it, ,, renew the condencers, Then it will be check soarse coils,
Lot of rain i hear Tommo",, very little practice done,,
