Mod 2 test....Getting a little nervous :-/
Echo" & the men,
Carb pod filters?
Aye slicer " it will run lean as hell , it will need choke on startup for a lot longer than normal, then thers the flat spot when given a big hand full,. The jetting will be a nightmare to get correct, if them guys have the proper kit sounds good , as you"l spend a lot of time and heart-ache setting her up, [ as they have ,to got where they are with the kit] Am a stock airbox fan,,
newb question/ 1968 Yamaha YR1 Shift pattern..
Aye Elliot" I think it be 1 down & 4 up with neutral between 1st& 2nd, as in most RD"s
yamaha ag 175
What tools are you using to file out ports and reed intake ?
yamaha ag 175
Yeh " are them cushion rings just to stop chatter,[ noise] . , some triples boys bead blast the steels, for more friction,,, Back up to the reeds, you say you may enlarge the openings on the cage,,,will the reeds still cover, are they plenty big.[overlap]?
Hola!
Beinvenida senor " Enjoy the forum,,,,
Water in the tank!
rs200
Aye ian , surf Ebay -thialand , is amazing what still out there, N.O.S too,
XVS125 1st Gear loss
I suppose its an unmeasured answer this,,,if gentle riding I think probably the life of the bike, I burnt out the clutch of my DT175 in 1977 . in 1 ploughed field ,got bogged and had to slip clutch to get out,, fried and knackerd completely,,
1973 hells angels documentary
I remember this,,,you gotta laff @ ,,,,on day release from the mental hospital.
yamaha ag 175
Sounds interesting " how you gonna mate the bigger carb,? and the filter side will be 50mm at least, you gonna fit a pod, filter, .? With them reeds you removed the buffers, does that work ok,,,
Yeh that's the good thing about these threads, . informs others A year + half " has got to be a record for a reply tho,,
yamaha ag 175
This a great read " very interesting ,, I"v always been wary of porting, but you"ve got it sussed, it same old story tho with the clutch, you get more power and she lets go,,,thers a yank company Redline , they do clutch mods, triples boys use them,
Hi
Welcome Marioc " a few pictures of YA 6 wuld be nice,,
dt175 clutch problem
Yeh " give her a good blast mallit, she should run clean after a few miles,
the beast of Turin
Good find drewps " bit normal for your taste
Hello Everyone
Welcome in benda" you have to sit the test in ausieland,?
Carole Nash MCN London Motorcycle Show 2015
Hi there" was this show at NEC Birmingham last year, ? I thought it was trade only, .
H2R on full chat
- Hello
Yes " DT"s are simple engineering,, when you take the plates off , hang them on summat [ in order they come off] , and install them in the correct order,- Mod 2 test....Getting a little nervous :-/
Enjoy the nervousness " its them feelings that make you feel alive,,,- Bikers are like Drummers
Hey Oj " threy"re the same the world over, ,, a few dicks the exception [ usually the white boot brigade]....- 83 Yamaha XT125 flywheel puller size?
Search your end for an item like this,, http://www.ebay.co.uk/itm/Universal-Flywheel-Puller-Tool-6-Sizes-10-14-16-18-24-27-Motorcycle-Tools-/250992924785?pt=LH_DefaultDomain_3&hash=item3a70581871- Hello
Hi mallet " the Zed is a heavy beast , hows the DT coming on,,?- Rear brake 125sr
Yeh oj" I use a lot of back brake in wet or gravely roads, easier to control if she slides,, - Hello
