WR400 - Supermoto Conversion + Engine rebuild
Aye ross " no chance of falling asleep thru first vid,,,the whole 7 secs,, ; Sounds good tho ..
Petrol proof paint or not?
Aye slice " give them a dusting of clear coat, ProXL does petrol resistant
Mod 2 test....Getting a little nervous :-/
Well done Raf "
Points for a Dt 125 A
Try jess bikes. [usa] thers lots of N,O.S in the states, have you a parts book? try and match them to CT3 DT175 ,, there all similar,
Xj600 flooding
Just a thought , if there no fuel coming out the overflow pipes, have you connected the fuel delivery pipe to the overflow, this would flood straight thru , easy done , as inlet spigot and overflow look similar, or fuel pipe to the vacume spigot, and on prime, will also do this, Did you jam the starter with lock-,,,hope the rods aint bent, ,, take out plugs and ventilate
GOOD LUCK ,,,
dt175 clutch problem
Paul " show him your tool , . aye the clutch basket holder,[ home made]
YX600 Radian Winter Project
I take it you like Black
yamaha ag 175
Enlighten us on the Square exhaust port ,
Its an easy fix you need to take off clutch the basket & primary gear, pull out old seal , and push in the new,,
sticky clutch
So what you mean is " its not engaging" ? look down at the arm when pulling lever, see if movement,,,or stuck as Airhead says,,
The Beast Is Dead
Ouch ! hope your confidence isn"t dented too. My last off was 10"th Oct 1976. remember it well .
Back! With another bike...
Good news that Edd" is the gearchange a linkage ? my old H2 had 5 down, on inspection someone had cut and welded the linkage,[ for drag racing] I just reverced the weld job, ,,
aye up from Nottingham
Hi M,fox" lol at mikes reply , But that's why you"l be on the scooter now,, aye report will be good,on 250x max
Pics of the collection
Great collection, must you mention the "hot sun" as were imprisoned in the white stuuf for the next 2/3 months,,
Hi
Hi blue, hope you get some answers ,,,
3rd DT175 Restore - 78 model
Aye she"s bonnie Mac " ,,hell its -5 degrees here, And heres you stripped to the waist,,,bah humbug,,, You kicking it over with flip flops too, I tried that with my DT 250, kicked back & bruised the sole of me foot . Un plug the offending switch , and see if battery & lights stop dimming, 6 volt batterys are easy drained,
absolute theiving gits! (NSFW, Colourful language)
Yeh greek" a trick I heard of,was some of the seasonal foreign workers , bring a number plate over with them, steal a bike and ride it home on the foreign plate,,
- YBR125 Gear Problems
Registration Costs & Benefits
Hi isa" the moderators will sort you soon, Reading some of the above posts , some paid up members then never returned to the site, another had his user-name changed ,and never came back ,
Helicoil Mac" ,, is it M10 on your mirrors,,, , looking good BTW,
What do you hate about xmas?
- What do you hate about xmas?
I like all of the above , .... I dislike the commercialism , overkill, And kev " not this year I hope, low tolerance up here now,,,- yamaha yr1 1968/ seals and bearings? bottom end rebuild.
Aye Elliot, when you remove old seals and bearings, take them to your local bearing supplier , they"l read the numbers on them, or measure them,, The only tool av ever used on a two-stroke is a puller type thing to pull the crank into the casing, u-tube has lots of engine build videos, u can make tool or buy it , "Tusk" is makers name,,[ usa made too]
