blackhat250
  1. blackhat250 replied to s900t8v's topic in Projects
    55 $" that's a steal, is there enuff room for the exhaust crossing over carb ? or is yours the side hung pipe,,
  2. Hi liegh " member Wild foamy is the DT50 expert , and may have parts lurking in shed,
  3. Missed this one,,, hes off tho,,,
  4. After regrinding them valves, clearance will be different, is it rocker or shims /bucket type,,
  5. Remember that green bar at bottom of screen " loading in" pah ,, if we never progressed from dial up ,, I think a lot of people would never visit online again
  6. Aye bip " thers an Island hopper ticket, you can do 3 or more of the Hebrides , it gorgeous over there, Shetland is a biggee " its an overnight ferry , leaves Aberdeen,[ East coast] , best small ferry is from Mallaig to Isle of sky,[ 20 mins ] then ride the island [ quite big] the exit over the Sky bridge , to great scenery and head to Ullapool , that's best for Harris [ stornoway] av never been to it before,
  7. Hi Gregg" good to see it being used as it was designed for,,
  8. Aye paul, original panels were colour coded, I cant post links now, as I upgraded to windows 8.1 . that's what they call progress eh,
  9. Brill ". keep us posted, will meet up , an advise best routes ,
  10. Superb bip " 200miles ,,
  11. Not so much ankles , its the bruised sole if poor footwear is worn
  12. Yes it wood " , lol at the spelling,, the plug lead is where moisture gathers, unscrew cap , WD 40 It , also... welcome
  13. God " shes a young lass, I thought she was a woman back then,, ,
  14. Hi dsb" it be a YZf if shes a 4stroker then :eusa_shifty:/ is she fuel injection / or carb, av seen a few of these in mates shop, pigs to kick .
  15. You"s are no wize,,,,,,,
  16. I remember some cars of old, the starter was drawing all the power, and only when letting go of the key, it fired, as releasing the key allowed bigger current to the coils, I"d say starter id suspect,,, as it fires with kicker, ,,, Also when I read the topic " two sparks then nothing" I thought this was another Wild foamy love life speil ,,
  17. I wouldn" t take out bikes, the corrosion will be horrendous,
  18. Am thinkn thers a fault with the timing chain line up too , that's maybe why it had a bent valve ,[ pervious owner] I hope you havna bent a valve again , when the chain slipped, the bottom sprocket has to be right - as its on the crank,,the top sprocket ? cam shaft ? is it located correctly, what state is the tensioner in,, are the prone to fk up ...
  19. Hi spur " av been to N/C, Elizabeth City, and cape Hatteras , warm state mostly,
  20. Beautiful "i like paint ,rather than powder coat,,
  21. Our roads are black slime. with salt, they put it on every day, Do they not salt the roads down south,,,
  22. :6 days have passed " and all is Quiet....
  23. Sounds interesting right enuff, that clutch idea will burn it out pronto, Quick shifter would be better, switch is on gear lever- breaks the spark , allowing fast shifts without break in drive train,,,
