Hello and help needed
Hi stuart " the biggest difference is the YZ /MX is about 30 bhp , [ bigger carb and big porting ] front forks will be bigger also diameter & lenth .
Dt125 power valves
Possibly a restricted model, with the gubins removed,,
v75a
Hi frank " another V70 owner lately ,,
Yam 175IT 1983
Aye ski " Enduro bikes were basic , as they were gonna get dropped, no fineries on the IT"s ,, what you got was a ported motor, DT175 15BHP - iT175 23BHP, bigger carb too ,
new bike dilemma! D:
Capt " the MT07 is great [ check write ups] cheap too, The old Fazer600 , are cool , And the Triumph street675, [ daytona frame] best handling ever, If I buy a new bike , [ havn"t since 1976] it will be either a Yamaha Tracer, OR 800 Tiger XR
loud knocking from bottom end.
if you pull the clutch in does it quieten ,?
Dropped the damned bike !!!
Bugger slice ", big bikes are a hand full, thers no stopping them , Tasky " you were lucky,, saved the TANK " ,[ as dt50 used to say ] , Am woking on the DT at the moment, I can pull it and the bike hoyst around,,,[ 120kg]
1996 yz 400
Early Kawasaki"s were like that, used to rev theyre nuts of when on choke,[ great way to fk the cams, oil slow to reach them ] I think your too lean , [ mixture]
Aloha
Hi vario " , your the bikers of the future, you sound keen too...
XJ600n (00) after market exhausts
Just watch and not shear the exhaust studs, on older bikes plenty penetrating oil days before the job, or it may turn into a big job, [ head off to drill out studs, ]
newbies r6 won't start
Hi zul " whats a low jack ? and damper, new battery will solve starting ,,etc, Is there an alarm on it,,, these kill batteries
1996 yz 400
If its valve clearance , it will be hot start that be the prob,. that pilot jet is blocked, as soon as choke is off , pilot jets does first 1/8 throttle then venture speed brings in the neddle jet, then main when on Wide open throttle,, By all means check the clearance tho ,,it all helps the running,,
Still no joy starting the XVS 125
She should fire if everthin is good, summats up spur, re-check spark and timing , as your getting fuel,,
thiml of getting fjr1300as on 57 plate
Hi puddle " , better fit a lever, as braking to a stop will result in a stall, shes a heavy bus too,,,reliable too
That's a bugger spur,,, jump it from a car battery,
been thinking of paint for my bike
I like that tommo" , check out u-tube spaying tips ,,,and go for it
road rage, sort of
Yeh " if you have an incident, [ argument or gestulate ] with a driver, it effects you for a while, don't dwell on it tho,
Hi there
Hi rhys " your an old newbee then ,,,
Carole Nash MCN London Motorcycle Show 2015
I saw show on Motor TV, [ the bike show] looked a good show,,, Scottish show on the 7/8th march , will be there,,,
Quick Intro
Them are cool wheels , red hubs or rims,,
Help needed please
Be seal on 2 stroke pump, filling the gearbox,,, on a ????????????????? Edit" I see you"ve posted this exact thread on the DT FORUM, so it be a DT 125 ? DTR ?
Yamaha ybr 125 help plz
Ok " so its fuel then ,,,whats the carb like,,,and is there fresh fuel in tank,
[ Quote kevthe rev , rule out big end ] So was I kev "
2 sparks then nothing
" Bang " Explain
At least we know its not the engine , as kev says thru the footpegs, = sprockets or chain, My tiger did this on over-run last year, it turned out front sprocket was hooked teeth,,
