blackhat250
  1. Hi glen , lots of dt fans here , for tips , picky please ,
  2. You don't need to change 2T oil, as its used up,[ totall loss] . change the gear oil every 5000mls,. coolant , every 3 years,
  3. Hi mrc" , , have you built it, [joined cases,] . theyre simple enuff gears, .have you got the side casing on , [ clutch cover,[ as you may have pushed the gear shift shaft thru. and the selector teeth on the pawl slipped out of line, thus as you try to select gear, the pawl jams against the bottom of case,
  4. blackhat250 replied to marccleave's topic in Projects
    Great story marc "
  5. Them two are bang on " if you want more noise , go for the whole system [ BIG ONE] We used to take out the baffle back in the day = louder & pissless,
  6. Hi roy " the DT250 was POiNTS up to 1980,. is it after market system ? I think it would be carb more than CDI,, as there reliable,
  7. Anti freeze " you southern softies won"t need it ,. its hardly been below 15 degrees down there ,
  8. blackhat250 replied to s900t8v's topic in Projects
    Ha 900" for every + theres a minus eh " the power is up, but the clutch slips, bugger, with these stiff springs, hows the lever pull ? And what CDI did you use, ?. the iggy box may have the curve built in, [ see Rex speedshop website,] , and you can beadblast the steels for more friction, but this increases wear on fibre splates,,,, + & - again eh,
  9. Welcome inn steve " ,,,
  10. Hi there ", that's some user name . yeh fire the questions in workshop,
  11. Yeh its cool jet " ,, now no tampering with them plugs while your soldering,,, ----------
  12. Welcome". theres a few draggy owner here, some modified, start a new thread , in another section , this is newbee section,.
  13. Hi there ", bit more info needed , ie - is there a spark, / fuel etc, but not in this section, start a new thread , [ worshop section]
  14. Yip " same here, [ can not display page, ]
  15. Bugger me " how long you had it ,? , Aint a year yet ,
  16. gOOD FIND RACER, " , I thot someone wudda answerd,
  17. I liked the custom XS250/400/650.
  18. IS it stil on warranty capt " could be T,P.sensor, or moisture in the conection , . it needs plugged in to see what fault code is.
  19. Phew " I thot is was just me, and windows 10....
  20. blackhat250 posted a topic in General
    I noticed the MORE " icon has gone, replaced with Online users [ like old forum ] and the smiles have a diferent icon, ? and no entry to Random,,still
  21. The timing is out Sandeep.... 2 or 3 degree BEFORE t,d.c . is needed , move the Stator plate, to mark ,,
  22. Que -- Jimmy with his opinion on the Great XS250
  23. I use an O ring chain , there sealed, so I just clean it with an oily rag,
  24. Cute tommo " my Golden went this year, am waiting till am retired , before I get another,
