blackhat250
  1. Hi alan " that's a weapon that is,, be carefull with it,,
  2. Try another plug, for a start, then check for fuel ,[ flow out of tank, to carb].
  3. Iwas experimenting yest, [ on dt400], when it got hot, [ 400f on tour tech ] it started to surge & pink, stopped, screwed air screw in 1/2 a turn, . it ran 10degree cooler.[ 387 the hottest, all day, ] and was smooth on over-run, another experiment, on a steep downhill, [ twistys,] I shoved on the choke, / it was like an engine brake , smooth, and the temp dropped 50degree in 2 minutes , so air is the killer of 2strokes ,
  4. Welcome Alan,, 535 "s are good wee bikes..
  5. https://www.google.co.uk/maps/place/Hepworth,+Holmfirth,+West+Yorkshire/@53.5608295,-1.8209761,12.5z/data=!4m5!3m4!1s0x487bd9ff560b7cdd:0x1314d1686d274254!8m2!3d53.5583434!4d-1.7560222
  6. Hi crosserk" Heres a link , join forum First, THEN ask for info , thers a guy on there does Dating certs, http://yamahadtclub.proboards.com/
  7. sUPERB, " oilcan café is in Hepworth aint it,, me being 300miles away ,but I know my geography.
  8. Square section swing arm, - guess 1979/80
  9. Yip ,shes a DT175MX, Same as airheads, [ member, ] put up pics ,
  10. blackhat250 replied to Mcleod's topic in General
    Ah Mr sasha " , [ see other newbee post Hello very happy here,,,]
  11. blackhat250 replied to Mcleod's topic in General
    Welcome Mcloud [ lord of the isles].. good to see your back on 2wheels,
  12. That's a strange intro Mrtone , , as if you were talking to someone else,
  13. Aye malleus " if I mind right, [ when I did my Zed 900] . the two cam shafts have a mark,[ arrow or dot.] , . and they either faced one another , or were 180¬ DEGREE appart, . when flywheeli s at TDC, THESE ARE WHEN YOUR FITTING AS NEW CHAIN, but , line them up as manaul says, before your remove the tensioner, .nothing should move, if you don't turn engine when old tensioner is removed, go on you tube, watch a few vids, . listen carefully, and learn ,,
  14. Look for the voltage regulator, [ online manual,] and renew , not headlight,
  15. That is good advise from Mr sacha " ............
  16. Welcome,, a few ownersi in here, , so help should be along,
  17. When the air screw is turned fully home the engine should stumble & conk out, as yours never , = means the pilot jet is too small, , what like is the spark plug colour AFTER a run ?
  18. yEH eg" thers a few in here, they"l chime in soon ,
  19. Hi POA " ..
  20. Yeh snack"s, you"ve dived in , shudds ,cleaned carbs too, [ if its been standing for months] . fault finding time ,now, [ electrics, ]
  21. Big kev "
  22. Hi flame. put up pictures, sounds different,
  23. You got picky of jets,?,, ARE THEY SMALL HEX, brass . , set the clip [ needle in middle groove, run it , [ short run ,] and plug chop, see colour
  24. Whats happening dave, ? can you not open throttle without bogging?, is it spluttering thru midrange, ? what colour is plug, sounds ritch ,
  25. Rainy days = shed time,, here the engine split, water ingress , and the crank seals were in wrong way round, mains solid. and the detent plunger was in wrong, [ some one prob thot it was the sump plug ] and stuffed it back in wrong, crankcase splitter . And rusty crank ,
