blackhat250
  1. Graet intro bryn ", interesting project too
  2. It be a YB100 . ? max 60mph, if your 14 stone, = less mph, .
  3. Great intro Steve,
  4. M25
    blackhat250 replied to Mr Bignel's topic in General
    I hope never to venture into that part of the country again , I mind [ 1993] on way to france, we landed on M25 ,12pm, and it was gridlocked, , I mean " do these people not sleep down there, .
  5. Good start paul,,, week off, ? near squires time too.
  6. Check the lighting coil, [ Ohms]
  7. Has to be, as the shift drum, rotates , and neutral detent plunger, slips into the biggest indent on drum[ neutral] this earths switch, and lights on dash,..
  8. Aye chriis, I use Any van .com . its a shipping war type thing, great service too, you get quotes flying in from loads of vendors, . what bike,..?
  9. Hi Ronnie ", the usual neutral light set-up, is, sky blue wire, [ found behind sprocket cover], , take a look and see if tis still there, . it works by earthing [ switch on shift drum,] .
  10. I would drop 1 tooth off the front sprocket, . it will pull better, . I would leave engine, you need reliability , .. maybe electronic , ignition "
  11. Hi harry, try carol nash, , don't listen to that tosh about imports, no problem ,
  12. Ha " ANDY " yer mad,,, think I saw your trips somewhere,[ online] , mind yourbody weight is gonna knock a bit off the 250"s performance,
  13. N.IRELAND is in the UK, ,, and you have the numbers, that shud be ok ,
  14. Hi chris,, [ I thot I already acknolaged you]
  15. I would invest in a temp gauge[ TT0 ] about £25. its the best way to jet and run new bored /tuned 2 strokes, , I "v been jetting my DT400 , and have dropped from 190 main to 150. , and dot let anyone tell you the air screw and pilot affects ONLY , idle and 1/8 THROTTLE. , I turned air screw in 1/4 turn, and running speed temp dropped 20 degree F, . get the sensor to suit your spark plug size , [12mm / 14mm] heres a link, [ usa] but you get them in UK,.[ search] http://www.ebay.co.uk/itm/Trail-Tech-TTO-Temperature-Meter-Digital-Gauge-14mm-Spark-Plug-Sensor-72-ET3-NEW-/381631066379?hash=item58dafbf10b:m:mMuD7UU-217AkY5q9559__A
  16. Welcome in neil, we were at Humber bridge lately on the FS1E rally , , wind on bridge was a nightmare, .
  17. Brilliantly said,,
  18. Welcomen",, , am with carol nash, they do fleet policy.. 2 classics & a Modern bike, no hastle,,
  19. Yeh jimmy" 600cc liquid cooled 2Stroke, Scott Squirrel . also a modded version was made ,Silk, . Tommy XS looks cool too. , Kev, is it Red " , with all that polishing ..
  20. http://www.aircooledrdclub.com
  21. blackhat250 replied to Saulito's topic in Classics
    Yah, Factory spec, "was" 32/1 . but oils are better now, 40/1 should do , ,either semi-synthetic, OR fully synth,
  22. Way aye Ma n ",,, you"l be hewcastle then chris ,,
  23. Yeh, I see why safety counts,, mind that family got chopped, when boat circled them, after the ALL fell out into water,
  24. Spill, whats the plan,,..
  25. Hi joe,,.. lots of Dt fans in here, & here , http://yamahadtclub.proboards.com/
