blackhat250
  1. Clean all the connections, ,check battery voltage too
  2. Hi tim,, pop up some pics,,
  3. Standard of driving is woefull,,,,,see it every day, they dont look at junctions, txting , & fone glued to thier ears,,,,
  4. Hi max" ,the CDI"s [OEM] are ok, am running the original , i had the Rex speedshop settup. and it failed , [ its him that says the old cdi"s are crap] , i told him it failed ,and his only reply- "weve done an upgraded version" ,so i said trade the old one against one,= No reply, So, back to the carb,,change the jet setter,[immulsion tube] and needle, as if they are worn ,more fuel get sucked thru ,. what colour was the plug ? ,,, Read this. see what i mean , https://yamaha-enduros.com/index.php/forum/performance-improvements/7305-rex-s-electronic-ignitions
  5. Hi martin ,, did you over oil the filtre ?... , what colour is the Plug,?, next time she splutters, shove the choke on ,[ just to see if its fuel starvation ], if its worse with choke ON, ,then shes neEding AIR,
  6. Hi lee, Am surprized a YZ has a battery, they usually start on a magnito system, The value will be on demand, and ebay is the shopwindow nowadays,
  7. Hi ed" , great wee bikes them 700"s......keep their value too, /?
  8. blackhat250 replied to bippo's topic in General
    We had no rain for months, and you"s managed to find some,,? , .its bonnie up there if suns out, https://imgur.com/wj2GAp2 https://imgur.com/wj2GAp2
  9. blackhat250 replied to Baz123bikes's topic in General
    Last of the twinshock model, 1G1- 1977/78 ,, should be silver /white fenders, The 1976 = 559- Red with white stripe,[ Nayruff avitar].
  10. Welcome in Windy ," post up pictures ,, not familiar with this model ,
  11. Speedometer is not part of the M.O.T., And your headlight beam can be altered by using a bit of tape in the right place, .
  12. blackhat250 replied to bippo's topic in General
    Thru the week is best,, the weekend warriors from the citys are out on the roads at weekends, ?
  13. sOUNDS LIKE FLOAT LEVEL, , i would also remove the float valve , and clear the passage
  14. .. inn,,,,,,,,,,,,,,,,
  15. Hi there, you sound like ur from the states, great vintage enduro following over there,
  16. blackhat250 replied to bippo's topic in General
    Bealach na Bà, is awfull in wet, esp if foggy, i have only seen the top once in 3 trips to Apple-x, , thers a small ferry at Corran ,5 mins and your over to Ardnamuchin ,peninsula from there you can do Isle of mull [ 20mins ferry] , or loop right round to Glenfinnan, viaduct and loch , ,
  17. Hi AULD EEN ". that sachs be german eh, they made chainsaws etc, Sachs-Dolmar,,,
  18. blackhat250 replied to bippo's topic in General
    Hiya Bip",, its been awhile,, forcast crap this weekend,, typical eh,,,,
  19. . Inn.....................
  20. blackhat250 replied to Folly66's topic in The Bar
    Yeh even the twinshock is different from the Mono-shock, as the cable enters the cases in different location, i HAVE a N,O.S bottom half [] both cables ] for the twinshock DT400, but am not using it, its worth more in the bag, ?
  21. blackhat250 replied to Folly66's topic in The Bar
    Read this post ,, no deffinate lenth yet,,, am rumnning a Dt175mx cable, https://yamaha-enduros.com/index.php/forum/1977-forward/8295-1978-dt400-oil-pump-cable-lenght?start=0
  22. blackhat250 replied to Drmskul's topic in The Bar
    Points model i take it, ,, renew the condencers, Then it will be check soarse coils,
  23. Lot of rain i hear Tommo",, very little practice done,,
