blackhat250
  1. Hi nelson" i"v been to Elisebeth city N.C. and Cape hatteras,,, nice part of the world,,, post up piccy of the XS..
  2. Yeh steve" Ace bike. rode the FZn [ naked] over Ireland, great bikes . power- handling-Looks,, its got em All .
  3. Ah airsick " your DT125 is a two-stroke,,, smoke is healthy. your knocking could be a rebore needed. it be piston slap , you be hearing. or crank bearing, but thats usually a rumble,,,small end. is a rattle,
  4. Oh yeah ryan more underhanded deals to suit honda,,,,
  5. Yeh , get the plugs out , then crank it over without plugs, to empty cylinders,, your oil will be contaminated too. check & change, then inspect the petcock ,as it must be passing, . before intalling plugs check for spark,, incase your on wrong problem,,, .
  6. Welcome Andrea" piccy"s please.. ...And another gel " last newbee had about 50 replies, how did you slip the net,,
  7. blackhat250 replied to BillyV's topic in General
    Another money making Scam
  8. Aye reme lad " usual simptoms of worn rings is blue smoke, and crankcase presure build up. i think it be detonation you be hearing, try the higher octane fuel ... loss of power = leaking exhaust,,,
  9. Welcome marcus" thats a cool colour, like the old KH400"s purple...
  10. Sounds about right tony" urban cycle will burn more . stop-start. at lights etc..
  11. The different fuel thing , well the tankers all que up at the same refinery[ Grangemouth up here] bound to be the same stuff,,,
  12. Hi victor [ Meldrew] /// your into cruisers now then,,, lots of info& owners,, on here of the 535
  13. This emissions thing was a big fad " Diesels are the worste pollutors, It was Honda that wanted 2strokes fazed out of GP racing. the practically own the F.I.M. and low and behold , the"ve got rid, of 250cc Gp &125cc Gp races,,,, replaced by Moto 2 = 600cc [ Honda engined bikes] I bet Aprilla are sick , as they had the dominant 125cc 2T, Gp bike,, If evolution had carried on, the 2T engine would still be the fastest & most powerfull engine ,
  14. Welcome george " the float Valve will be worn, or crap in it,, take it out and inspect... Stiff gear change, , is this wen oil is hot or cold,,,,you may want to post this queery to workshop. ,,
  15. Yeh with Kawasaki colours,,,,,,
  16. Hi Andrew. the carb needs an air filtre for restiction ,as the over lean mixture causes poor pick up at low throttle openings,, Also check the pilot jet is clear, how does it run with choke on,,, Start a new topic in workshop,,,,,about this problem,
  17. Welcome rab. foamy thers an article on the turbo 650 in Practical Sport. bike mag this month...
  18. Were on tunnel the 8th. heading right down to St,tropez, so if you see old 2strokes ,it be us..
  19. blackhat250 replied to kristianybr's topic in The Bar
    Yeh " and if you"ve got fuel- spark. .. whats missing is compression,,,,
  20. Welcome charly " post up in workshop, someone will know...
  21. When you going norcot " am going sept10th, heading to pyrenese. Plinningas [ member] as experience of europe,,,
  22. blackhat250 replied to kristianybr's topic in The Bar
    What were the symptoms seconds before it died, ie. was ther a knocking noise "[ crank] or a gradual slowing, -smoking- excessive heat,, we need more info. was ther a light on dash. i mean how did you know to look for oil, if motor dies most causes are fuel related.or ignition..
  23. Drop the oil, [drain plug] then measure it in a jug, , The neutral thing is because your clutch is dragging. adjust at lever,
  24. Ah " youve found the post. low on oil will give change issues too.
  25. Welcome trailout " i thot the Admin"s name was Alex,,,, but there you go " good weather for runs the now eh,,,
