blackhat250
  1. I have to press register, then if i select forums ,or home logs me out,,,,
  2. Fkn glitch. need to sign in with Pussbook,,,,?
  3. Its wonky again,,,,
  4. Hi there, the pawl behind the cluch basket,. maybe need a spring, [ broken or fallen off] ,take off the side cover again, and get some one to select gears,[ engine off] see if its grabbing the selector drum, its a claw, turn the back wheel by hand to change up the gears,
  5. Yip,,,,put up the number on case,, is it air-cooled ,?
  6. Your A legend bip" . well done,,, and good on the horn. life savers they are ,,, dim-wit drivers?
  7. Hi andy ", the F2 Its a valve aint it, half faired ?, . And jimmy didnt say what glorious 4T he bought did he ,
  8. Amust nowadays, with the hoodie morons on earphones,,,
  9. Hi XJ", site was crashed for few day"s,,,,
  10. blackhat250 replied to Alex's topic in General
    Yeh " i thought we"d not payed the bill , and they pulled the plug,,,well done alex
  11. Hi there, its a grey area that, a snood maybe" , i find most suits leak at the crotch ,,,
  12. Hi Cris", was this the same as the XS500, ?
  13. Hi alex" ,, i was out today , no salt on roads, 12 degrees, hope this stays for a while, you"l get some riding done,
  14. h" ?,, inigma CODE of what ,
  15. Your on the right track,, what you need is a parts manual, to see if the rod is cross reference with other models , ie-= DT125/175 etc.. CMSL, parts europe may have them, search the site, https://www.cmsnl.com/yamaha-rs100-1976-usa_model8571/partslist/#.W-2_E-j7RqM
  16. Hi biff" simple wee engines these ,
  17. Hi Cary". big old bus them,, they used to do the Proddy racing,, with good results too, . seen the picture, not shure what that is,
  18. Define High Fat" what was the vice ?
  19. Yeh NSD, been the best summer since 1976, Did a few longish trips, ticked of the list, ,but our summer ended fist week in Aug,, i noticed you lot down south had high temps right into Oct,,,
  20. You can fit a slightly wider tyre on than standard, it pulls the tyre into a slightly more peaked shape, they say it makes you tip in quicker on corners, well i fitted a 190- on instead of a 180, and noticed no difference ,
  21. I would check the Flow of fuel, first,, yours will be carbs i take it, ?
  22. Good for me merv" ,
  23. Wow " shocker jase" i feel for yeh,,, what brings this on ,,lifestyle? or hereditary ?
