blackhat250
  1. Leave it till you"ve tried it, if its rich it will 4stroke [, kinda splutter] at a steady throttle, the biggest damage that can occur when jetting is at W,O.T. on long staights, or hills,
  2. You lot havin a PICNIC in here,,,
  3. What about it running better with choke removed, it should bog right away , unless stone cold,,? Unless its pulling air down from top ,then no vacume to draw fuel up thru choke passage, this would make it rev cleaner,
  4. I was on wrong picture /model,,, I clicked first link,,,
  5. blackhat250 replied to Noise's topic in The Bar
    Good to test ride tho,,, get the feel , the America is a nice triumph too.. And I think " Kevs a nutter,,
  6. Hi Naomi " that's a bargain allday long,
  7. Heres mine , check the choke pipe leanth,,, ">http://http://s1110.photobucket.com/user/Blackhat750/media/P1000524.jpg.html'>
  8. Lets go back upto pcture of your carb, The choke feedpipe is too short, to dip into the well ,[incarb bottom] so I think it aint drawing fuel WITH the choke removed, it be drawing air ,, your thought s Paul
  9. Hee " you get the point, ,well it musta ben starved of fuel , or she would bog
  10. 13 is a gasket. & 35 air chamber,,,
  11. That's it. you copy from other site,
  12. Lack of air, ie too much fuel,,
  13. Funny" that's what I used as a tank too, and my 250 emptied the syringe very quickly too ,
  14. Tommy " I"v just removed you from my friends list, and will intentionally forget my WD40 , next yea r The spocket is still on by the way,,
  15. Run the cursor up to the browse box [top left] left click on it - it will turn blue - then right click - drop down box appears- click copy then click on your post on here, - right click - drop box -select paste. Do this with both sites open on different windows
  16. Are you describing inlet rubbers ? a picy would help ..
  17. I usually take out the jets to see what type they are, then go on ebay ,search mikuni jets, [ size] and compare the types, Good the plug is standard,,,
  18. blackhat250 replied to Noise's topic in The Bar
    I think Morton are crap,,,
  19. Why did you go up from a B8 to aB9 that's a colder running plug,? you say its a bit sooty, ,,,
  20. Aye slowly" how does it run,, main jet affects Wide,Open,Throttle only , how does it pull, and plug colour tell a story,,,
  21. blackhat250 replied to tobi evans's topic in General
    LC350 . like kevs,, just modified ,,
  22. blackhat250 replied to tobi evans's topic in General
    Hey " that's an LC,
  23. Well since my DT250mx is a non matching numbers bike , am changing the colour this winter, Av got the decals,,, http://
  24. Yeh " and if that don't work ,check the choke system,,
  25. Good"o simon, your lucky to get riding, its rained up here Every day for 2 weeks,,
