ozzyfzr
Everything posted by ozzyfzr
  1. "Zoomsplat" best describes a Harley!!!!!!!!!!!! Zoom to corner then Splat into the wall!
  2. ozzyfzr replied to ianxjr's topic in Yamaha Gallery
    Nice lookin bike mate! lovely colour goes with the dog
  3. ozzyfzr replied to GazLat's topic in Yamaha Gallery
    Wicked lookin bike that, love the wheels, not sure about the headlight tho!
  4. ozzyfzr posted a topic in The Bar
    Just a short introduction, I lived and worked in the UK and then emigrated to Australia, been a member on several other Yam related forums and just found another! spotted some familiar names already, looks a top site so the beers are on me!
  5. Has it been standing long? some clutch's have been known to stick, push the bike upto a wall, start and engage gear and hey presto it free's up! long shot but it maybe stuck!
  6. when I first got it repainted after light crash, various stages of build All work by myself, including all painting and airbrush work
  7. ozzyfzr replied to a post in a topic in Yamaha Workshop
    I'd also hazard a guess the valves may have closed up! dealer should check Carb mixture Fuel flow/pressure/float heights Carb Balance Valve Clearances Ignition timing Def get it sorted quick or you could end with a bigger problem than you have now!
  8. I'd also drain the float bowls and check for water! def sounds like fuel starvation!!!
  9. With the ignition off turn the servo-motor slowly to another position from where it is! , then when you turn the ignition on the servo motor should bring it back to it's zero position. I would also check that the carbs have been synchronized properly and the air-bleed screws are set to about 2 turns out. Common issue is the exup shaft does seize-up and can cause problems, just like I say above see if you can move it by hand (should be relatively easy). Check the cables are not frayed also this can cause exup-stutter!
