S.Gjaltema
  1. S.Gjaltema posted a topic in General
    Hey, hey, Look what i've fond, http://www.yamaha-motor.co.jp/global/enter...stic/index.html fun
  2. Hy, I've just changed both seals on my front fork legs. I had no problems doing that, they came out easely. But instand of using my wife i used a self made lever to push down the spring while removing the circlip. kr, Sicco.
  3. Yipee, problem solved. I changed the engine oil and used a non-synthetic oil. And miraculous the clutch isn't slipping anymore. kr, Sicco.
  4. Thanks a lot, It was indeed the new synthetic oil of Castrol, so i think you're right. I just made a few miles to test the bike with this oil and immediately the ride i drained the engine. So i hope with new "old" oil the clutch won't slip. kr, Sicco.
  5. Hello, I have a bit of a problem. After changing the engine oil (SAE 10W40 Castrol) the clutch is slipping. The bike has run 30.000 miles, do i need new plates, or another engine oil? There is some slack on the clutch-cable. Appreciate any help. kr, Sicco.
  6. S.Gjaltema replied to raney's topic in Classics
    This one is better, http://www.motorcycleweb.nl/N_frame.html?h...rp_14_23-1.html Kind regards, Sicco.
  7. S.Gjaltema replied to raney's topic in Classics
    Hello, This guys are disassembling a xs400 perhaps they have a rear shock http://www.marktnet.nl/rubrieken/motoren/o...q=xs400&p=1 Kind regards, Sicco.
