solorider
  1. try this site,they do tuning stuff for a lot of bikes,how deep is your wallet http://www.50cc.nl/frameset_eng.htm?zoek_e.asp~CcMainE ,they are based in holland and prices are in euros
  2. any of you who needs any spares i can give you a phone number of a man who has loads of spares,alot that are now no longer available,he has spares for bikes from the 70s to the 80s mostly and has a lot of fizzy spares(sorry no rear lamp brackets) if you want the phone no e mail me on [email protected] and i will email you the no
  3. solorider replied to Beezkneez's topic in Naked
    the aussies have it even better,so long as they keep their vehicles in good condition they dont have to have it tested at all,but if they do get stopped they may have to have it tested
  4. unless you have a late model dt you should have a steering lock built into the ignition switch,try turning the bars either way,with the ignition off push the key in and try to turn anti clockwise,dont force the key if it wont turn then you have the later model,i have a 1989 dt and that has 2 steering locks and i dont have the key for the steering head lock and the key never matches the ignition key
  5. if yours was an exup there are 2 sets of carbs for sale on ebay
  6. that happened to me on a 1977 rd250,after trying to do a u turn on a main doad and hitting the kerb,the bike leant to the right but i couldnt put my leg out cos my trousers were over the kick start "what's yours then? mine is as follows.........petrol station on the rd400, jump on bike, ready to start it..... and what's happened? kickstart up me trouser leg(bootcut jeans)! an i topple over felt like a right tit i did still dont know how the hell it happened. one of those stupid off days i guess"
  7. so long as you dont give a bad reply or give a police man a bad attitude most police men can be very resnable,i got pulled doing 37 in a 30 and all i got was advice about late night drinkers were about,no ticket or producer,mind you i did also go through a radar trap with the van i was driving off hte clock and never got pulled over,mind you the motorcycle cop did wave his radar at me! the speedo only read to 85mph
  8. on ebay there is some gold star calipers for sale,item7963533977,at the they are going for £71 and he has the matching master cylinder,item7963534402.both have 2days11hours to go
  9. i believe the 2003 models had the gold star calipers,if you notice new models with radial calipers have smaller discs to save on unsprung weight,which is what yamaha probably did on 2003 on models,i dont know what the disc sizes are for each year but if you bought the matching calipers for your forks you shouldnt have any problem selling your blue star calipers
  10. [if it is a flimsy metal one buy another the ends of the tang sticking out have either broke or wore away,the part is not expensive
  11. all 4 cylinder bikes will vibrate at a certain revs,if the carbs are balanced it is better to adjust your speed to suit or alter the gearing
  12. why not just go and buy the correct calipers for the forks? it would save a lot of hassle and losing 10mm on the disc size wont make a lot of difference if any,with the correct calipers you may get better brakes
  13. solorider replied to Chris's topic in Naked
    what a lot of people dont check when they think of cam chain noise is their carb balance,if there is an awfu racket out of balance carbs can do it or even dirty carbs if the bike has been stood over winter,especially if the bike was ok before the winter ignore the above if you have a single cylinder or a 2 stroke
  14. as regards the fairing the tzr as standard never had a fairing,it was an optional extra,the bike you are looking at looks quite clean but if you do decide to unrestrict it you do lose some reliability,all those saying peg the power valve open that is all right untill you have to run it in,then you will wish you had a working powervalve!
  15. your running problem in that it would not run below 3000rpm,i had the same problem with my dt125r,and that has had a rebore and has only done 10 miles on it,the bike seems to run better since i adjusted the pilot screw but it is not perfect but then it did idle for the first time since i got it.the carb is clean so it isnt that and the fuel pipe is brand new genuine yamaha,my bike is standard except for a dep exhaust ,working power valve and performance reads (1989 model)
