mr benn
Everything posted by mr benn
  1. Flitwick Motorcycles are excellent for mail order. They charge a nominal cost for postage. Very knowledgeable and friendly.
  2. the people that do the rebore will normally supply you with a piston kit, but get a small end bearing as well. I waited while mine was done - it took about 2 hours for 2 cylinders. you should remove the power valve to stop it getting full of swarf and debris. and drain the coolant at the pump before you start taking it all apart. you can get the bits from you Yam dealer but they'll be more expensive than your reborer. Just make sure you get a decent brand of piston - ART or Mitaka. I used a place in Waterloo or Crosby, Liverpool - just can't remember who it was!
  3. mr benn replied to bodgley's topic in The Bar
    is it possible you've disturbed the float height when changing the emulsion tubes? this could cause fuelling issues. is the TPS properly connected? could it be old fuel? This website is pretty good for TRX info: http://trx850.motomaniac.net/forum/index.php
  4. mr benn replied to bodgley's topic in The Bar
    almost no clearance is not good but when you get zero clearance you will have problems starting. DJ kit has no emulsion tubes in it. It contains needles and main jets. you can buy emulsion tubes from Kedo in Germany for about £10 each. Sounds like you may have created a problem while changing the emulsion tubes if it's not fuelling correctly at higher revs. Rich running can cause bore washing, where the fuel washes the oil away and leads to lubrication failure.
  5. when you say the front and rear lights blink, do you mean they dim and brighten a bit, or really flash? are you testing this at idle? have you tried revving the engine? it's possible that with the lights and indicators on there is not enough current available from the battery to drive everything, so it needs a little help from the alternator.
  6. mr benn replied to lukey's topic in Naked
    it's a 125. it probably won't do a lot more than 75. the red zone is there for a reason.................don't run the motor there continuously.
  7. buy a bigger bike. The SR125 is not exactly tuneable.
  8. what colour is the plug when you remove it?
  9. Yamaha, naturally, but at some cost. Try www.wemoto.com
  10. ThunderCat has much better suspension than the Fazer. As said, depends what you want in a bike..............what do you want?
  11. mr benn replied to TDM878's topic in Naked
    2MA - jap import? Think many jap home market bikes have a speed warning light fitted.
  12. a bike will only benefit from a steering damper if it's very quick steering heading towards slapping its head abut. as said a ThunderCat does not need a damper. if your tyre is shagged then fit a new one. you'll think you got a new bike.
  13. too much oil does not mean the bike is running rich. it will in fact be running lean as there will be too little fuel and too much oil. what does the plug look like when it is defunct? colour? wet? dry? cracked?
  14. you have an intake air leak, i reckon. Could be a split in the carb rubber or the clamp not tightened properly.
  15. sounds very much like Exup needs stripping, cleaning, greasing and setting up
  16. are you saying that the diaphragm is detached from the silde? you need a new slide - it comes with the diaphragm attached. are you saying the diphragm won't stay in it's groove on the top of the carb? a smear of grease in the groove will hold it in place til you can get the cap on.
  17. Dunlop recommend a 170 on the back of the Cat. I didn't like it on mine, but some do.
  18. mr benn replied to bodgley's topic in The Bar
    like wicky says, emulsion tubes for sure. not a major job or expense.
  19. car racing? zzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzz now, World Superbikes at Monza is a different matter..................
  20. if I were you, I'd go to the carpe TDM website and ask there.
  21. Ducati 999 is off the pace? What do you ride? A Yamaha M1? Multistrada is a joke? One of the best all round bikes on the market. Triumph TT600......best handling 600 when it was released. what the fuck are you on man?
  22. Ask for the handbook. It will all be in there.
  23. what he said^^^^^^^^^^^ did you know the bike has 2 fuel taps? the one on the right often gets blocked with crud as most folk only use the one on the left. how do you know the pump is operating as it should? does the bike run ok on prime? could be a split fuel tap diaphragm. have you checked that the fuel and vacuum hoses are not kinked or trapped? have you tried to run it with the fuel cap open? could be a split carb diaphragm.
  24. Ebay normally has some.
  25. Well................for example...................Yamaha dealers can buy oil, plugs, filters, gaskets, shims etc from any wholesaler - they don't have to use OEM parts, particularly if you ask them not to. There's also www.oemmotorparts.com, where dealers can buy OE parts at doscounted prices.
