Rhino
Everything posted by Rhino
  1. Well for what it's worth I think you either have air or moisture in the brake fluid. It's hard to tell from the photo but does the fluid look a little bit cloudy when you look at the sight glass ? If the fluid doesn't look clear and bright then miosture is the problem and you should change the fluid. If the fluid is OK then the brake needs bleeding. I have a YBR and can tell you that there is no way to adjust the brake lever travel. One piece of advice is that if you don't feel confident to sort the brake yourself then get a dealer to do it for you. You have to be able to rely on the brakes as you may pay a much greater price than an hours labour if they dont work when you need them to.
  2. Thanks for the info YBR. I think i'll give one a go.
  3. hi, Was the bulb upgade any use YBR ? I've seen some halogen upgrades from RING that claim to give a better light as the standard one is pretty poor on my 2006 model
  4. Rhino replied to Steve4000's topic in The Bar
    Steve There's a complete starter motor unit on ebay at the moment for £50, might be worth a shot.
