windard123
Everything posted by windard123
  1. windard123 replied to stealthr6's topic in The Bar
    Thats a clean one you've got there, ive got a 2000 R6 and mine was real bad when i brought it a couple of years ago, spent a few grand on it and shes one of a kind now, im only 20 but passed my test 2 years ago and got straight on the R6, im pretty sure though that the 2 years restriction lasts till either the 2 years are up or until you turn 21 as thats when you can do your direct access, thats what ive read anyway!
  2. Ive just disconnected the intregrated indicators from the circuit and the stalk indicators still work but now even with the lights off the dash doesnt flash, i checked all the earth connections last week, cleaned them all up and made sure there was good contact and i don't see how there could be any broken wires as i was really careful when i had the bike apart to clean it, i was thinking that maybe if i disconnected the integrated indicators and then added a load resistor to each of the stalk indicators wether that would work?
  3. I think the majority of the microns baffles are removeable, if you look down the end of the can to the top there should be an allen bolt which just needs to be removed to get the baffle out, the only problem is that as its inside the exhaust heating up and cooling down all the time they can seize in really easily which is the problem i had with my old can so give it a good spray with WD before you try to get it out unless its a new one then it should be fine, hope that helps!
  4. I went out this morning and it turns out the indicators work fine while the bikes running with the lights on but the dash light still won't flash when the side/headlights are switched on, is this a simple problem?
  5. The taillight ones have been on there all the time but i replaced the front and back pairs with LED's
  6. Hi everyone, i wondered if i could get any help with this stupid electrical problem im having. I've just fitted LED incidators front and back with built in indicators in the LED tailights aswell (which were working when i had bulb indicators) and already had an LED flasher relay fitted but now when i have the headlights on the indicators dont work. When there is no lights on the indicators work and the dash light flashes to say there working but then when i turn the side lights on the dash light stops flashing but the indicators still work then when i turn the headlights on niether the dash light on indicators work, anybody got any ideas????
  7. Hi, ive bin wantin usd forks for my r6 for a long time and ive seen some of my year that have the older r1 forks on but you also then need the r1 wheel and yokes, i havnt a clue but was wondering if its possible to fit some 2005 usd r6 forks to a 2000 with only the fork legs and brake calipers? is the axel and yokes the same size as the 2000?
