gav2k
Everything posted by gav2k
  1. they look ok but there nothing like the quality of the originals so im not going there. the standard chain guard looks nadd tho so thats going for sure!
  2. gav2k replied to beowulf's topic in General
    go into the user cp (my controls) and select your country in the options.
  3. i like that standard heel plates tbh. the front tank cover is carbon..... cain guard is next i think...
  4. gav2k replied to whatsernamexhayz's topic in The Bar
    sporty looking..... cagiva mito - sporty looks 2t engine. aprilia rs125 - sporty looks again 2t engine honda cbr - sporty looks sort of 4t engine sach xtc - sporty looks 4t engine there is a list of a few that are still being made. have a look through google and you'll see good and bad points to all of them.
  5. the stalling is to do with your clutch bite not the chain being to tight. you should aim for 30mm - 50mm of play in the chain. if the clutch isnt adjusted properly you will find the clutch is biting then when you kick into gear if there isnt loads of slack the engine will stall like it has been. you need to wind the handle bar adjuster out till it stops or adjust the clutch engine side, not a difficult job. The chain guard is there to protect the chain and swing arm from eachother. you can pick one up from any dealers for next to nothing as its a disposible part that should be checked and replaced offen. Hope that helps mate
  6. yeah i do indeed. needs more carbon tho which i will be working on shortly.
  7. welcome to the forum, im new too. there is far to many yammy forums out there so i joined them all lmao!
  8. folow the st piping down to the engine case it should go in behind a cover. open this up and have a look. should really explain itself once youve looked. ive never worked on a dtr but all the 2t's ove worked on have setups that work along the same lines.
  9. not trying to defend tincan users in any way but in our focus to put the rear fog light on you have to pull the light switch out 1st click is fron second is front and rear. there is no option for rear on its own. and yesterday i did have the rear on cos it was f'kin it down on the m25 and i like the rear of my car to stay as it is!
  10. your using way to much oil there fella. bet its smoking like mad. i would be checking your pump asap to see how wrong its set.
  11. gav2k replied to gav2k's topic in Yamaha Gallery
    obviously not then or you would know straight away. lmao!
  12. gav2k replied to gav2k's topic in Yamaha Gallery
    Hmm ur name looks familiar.... not the o-cuk dd are you??
  13. gav2k posted a topic in Yamaha Gallery
    Hi all, Just joined and thought i would post up a few pictures of my baby!
