Burnsey888
Everything posted by Burnsey888
  1. RIGHT LISTEN HERE JAKE!!!! i have a malaguti xsm 2006 if you look on google and type it in the bike is identical to the Yamaha dt50R I have got my bike derestriced by my self and my bike has no trouble with 50mph i have had 60 on flat and 65down hill! RESTRICTS YOUR BIKE HAS!! 1. If you look on the exhaust there is a little mount with 3 screws take them 3 screws out and inside there is a little gasket remove this gasket as it is choking up ur engine! When you put the 3 screws back in put abit of exhaust putty around were the gasket would be to seal the gap otherwise it will be loud!!! 2. Place a bigger jet in the carb!!! 3. DONT BUY A PERFORMANCE EXHAUST OR 70/80CC BIG BORE KIT!! UNLESS YOU GET IT FITTED PROFESSIONALLY AND HAVE OTHER MAJOR BITS DONE TO IT ASWELL INCLUDIN EXHAUST, BIGGER CARB, AND RACING CRANK OTHERWISE THE ENGINE WONT TAKE THE POWER AND YOU WILL SEIZE IT SOLID!!!! 4. Get a Bigger front sproket which will increase ur top speed!! IMPORTANT!!! 5. LOOK ON THE EXHAUST THERE IS A PIPE WHICH LEADS UP NEAR THE EXPANSION CHAMBER, AND CONNECTS TO A LITTLE BLACK SILICONE TUBE TAKE THE TUBE OFF THE BLACK PIPE AND BLOCK THAT PIPE UP AGAIN I PUT A SPOT OF WELD ON THE BLACK PIPE TO STOP HOT AIR GOING INTO THE AIR BOX!! THEN REMOVE YOUR SEAT AND NEAR THE BATTREY WILL BE THE AIRBOX WITH A 90* DEGREE ELBOW PIPE COMING OUT THE TOP REMOVE THAT THIS WILL INCREASE REV AND MAKE YOUR PED SOUND BETTER THEN GET A MEDIUM SIZE DRILL BIT AROUND 8MM AND DRILL 4 HOLE EACH SIDE OF THE AIR BOX SO IT GETS MORE COLD AIR INTO THE ENGINE!! THATS ALL REALLY ANY PROBLEMS CONTACT ME @ [email protected] thanks dude have fun dont go to fast!!!
