navi
  1. Hi, you can find the service parts on http://www.yamaha-motor.com/sport/parts/home.aspx chian is 94582-10122-00 CHAIN (DID50VA8-122LL) rear sprocket 2D1-25445-20-00 SPROCKET, DRIVEN (45T Front drive sproket 5VY-13354-00-00 SPROCKET, DRIVE Lots of bike shops do race kits and loads of chains . hope this is of help navi
  2. Hi Ricardw, I have the same 08 Fazeer and so for am unable to fault it, but will keep the side stand switch in minds if it even cuts out, to date have done 6k on dunlop 211 that are not half worn and have good road holding navi
  3. navi replied to Goff's topic in General
    Wow Goff, what a photo show , and the bikes as well. you wont have long to wait for a replacement....... just wish I was in your age bracket navi
  4. navi replied to Zod's topic in Naked
    Givi do them as well as tank bag and rear boxs. Im not happy with the fastners and the side box are available now . try Busters for the best prices navi
  5. Hi Alex. simple ans is NO, most all are sealed units But the line filler should stop any bad stuff comeing from the fuel tank so i would check them out . Its normaly water in the system thats the problem on fillups and that dont stop the pump working you need to clean the carbs and tank out of bad fuel. to clean the pump just flush clean fuel through it. if there no suction the diaframs duff end of story. Navi
  6. For me it has to be the 2007 FZ1abs and like your FJ is faultless I would like a beger fairing and screen that said it to is a flyer with 150+hp and one need to use the 12k rmp unless wheelies are requied. navi If its not Ballistic then its Boring.
  7. For me it has to be the 2007 FZ1abs and like your FJ is faultless I would like a beger fairing and screen that said it to is a flyer with 150+hp and one need to use the 12k rmp unless wheelies are requied. navi
  8. Well ... that sounds just like my FZ1abs 2007 and i cant find the dam noise,, it dont slow it down any or make things not workso untill it shows a better sign of ware we have to put up with it. My H Hornet had the same noise that i fixed by removeing the screen and refitting, not so with the Yami. Givi do a touring screen that helps a little on the Yami up to the ton after that its keep ur head down and elbows in, if you hear of a full fairing let me know. navi like the speed but not the wind.
  9. navi replied to sim666's topic in The Bar
    Ohoooo dear that would p... me off, but could explain why you get a better mpg, I get on average 250klm for 13lt +/- » 156ml for 3gln from a 2007 ie I got new SEPT2007 . 102bhp at 110hp at 10,000rev redline 13.000 and it don,t hang about when you ask it to go keep having fun
  10. navi replied to sim666's topic in The Bar
    How cares about mpg when the main thing is to get the BEST mph/rpm out of the little darlings... navi
  11. Hi Mike, and welcome to the world of the "Biker". you have just had me in a fit of joy thinking of all the joy I have had and still have "being on her" and don´t want to get off. the strories/tails I could tell are to long and to many good and sad ones, but for you its going to be one hell of a ride. live the dream and stay safe . navi 66year old with 08 hornet600 and newFZ1
  12. navi posted a topic in General
    Hello and thank you for reading my request for help... I have a new FZ1 sa Fazer that has 700 klm on the clock , after a quick if you can call 7.000 rpm quick on the motorway for a short time and distance of only a few klm . on returning home I found grease on the center stand thats seems to be from the chain !! What I need to know is this normal... as I understand the chain should be sealed or have thay failed. This is the only thing that I can find faulty. its just a great bike to ride athough I would like a bigger flyscreen. If it is narmal for this to happen they there is no need to worry and shall not have to return it to the dealer here in Portugal. many thanks navi
  13. navi replied to JAYSDT's topic in The Bar
    Hi well in cold weather any engine will puff out white smoke (steam) gray to black is fuel. and blue is oil. if the white smoke is still there when the engine hot check the fuel for water . if there is you should have a missfire bad running and poor starting. chech for a clean plug. If it runs smooth and dont missfire ,,, dont worry . navi
