jimjam
Everything posted by jimjam
  1. The last pipe looks like our crank case breather tube
  2. Correct-a-mungo!
  3. jimjam replied to pedro3785's post in a topic in Yamaha Workshop
    I had something very similar from my RD YPVS, (they use the same counter). The first time it was a knackered battery and the second was the ignition switch. I took it off and cleaned up the contacts and it was like new again. Other than that have you checked for an inline fuse?
  4. I would do the following. Recheck your air screw it looks like it's more than 1 1/4 turns out. The white nipple looks like your oil feed in and the pipe looks like the oil supply. Your idle screw the one with the spring looks bent from this angle and you ought to take it out for insoection to make sure that the rubber O-ring is OK. This should be unscrewed about 2 turns and deternimes your idle. If it still does not idle then you need to take the bowl off at teh bottom and clean out your jets. IF you are not sure whether you are using any 2 stoke oil then stop and return to the basics. You must have air going in. You must have petrol going in. You must have 2 stroke oil going in. Once you have got all 3 then it's time to start looking for idle problems. As a quick check kick the bike over a few times and some oil should come out of the end of the pipe provided it's full. Be careful with this you could end up in trouble.
  5. jimjam replied to dtandy's post in a topic in Yamaha Workshop
    Skyline's got a good point I think. 2 stroke engines do smoke and the less you use them the more they smoke. Using a cheaper mineral based oil like valvoline will make the bike smoke a lot but the smell will not be the same as engine oil. Unless you think it's gutless then it's probably the 2 T oil. Is it really really bad or is it just that you notice it?
  6. I suppsoe that you're using a mikuni carb. I can only think that it might ne an overflow from the slide tube or one from the float bowl. Mind you I am not a DT owner
  7. jimjam replied to scud's post in a topic in Naked
    It is a good learning point to ride in the wet, it helps to get your head around driving when the roads have been wet overnight. Also it scares you witless as there are a lot of drivers out there who have no idea about increased braking distances or straight line braking. Doesent make my pants wet, just brown.... :shock:
  8. jimjam replied to Need4Speed's post in a topic in Yamaha Workshop
    Sounds like a sticky choke The engine won't run on idle when hot. Classic choke problem.
  9. jimjam replied to XT Alan's post in a topic in General
    I've been restoring a really crappy bike so I have loads of shite stuff to put back on it for over winter. It'll be used and I can se that the WD40 bill will be rising.
  10. jimjam replied to pedro3785's post in a topic in Naked
    That's a real bind for you Peter. Is the rev counter the same as many other Yamahas? You could probably pick up another one for £5.
  11. jimjam replied to LNicholson's post in a topic in Naked
    I could be tempted to ask an idiot 200LB friend to put his weight on the other footpeg.
  12. jimjam replied to pjones_po's post in a topic in Naked
    Roll the bike along is first on hi revs gently then close the throttle fully then 'wap' it open. gives a jerky wheelie but should do the trick. Or do a racing start where you ave the throttle fairly wide open then instead of feathering the clutch after your rolling just dump it.
  13. Another one in the fold. :shock: :shock:
  14. jimjam replied to beerbaron's post in a topic in Naked
    Don't use a compressor. Use a bike pump. It's only a few pushes. upto 11 PSI or there about. Try a lightly thicker oil. Go to Halfords and see their range.
  15. jimjam replied to N_Tart's post in a topic in General
    FUNNY
  16. jimjam replied to liquidcooled's post in a topic in General
    Anything - CAMEL. Blinking excellent
  17. jimjam replied to monty_onna_divvi's post in a topic in The Bar
    Yep I agree. I got a hire bike and drove to lands end in a day. the ride after exeter on the back roads was superb.
  18. jimjam replied to beerbaron's post in a topic in Naked
    I only know that you can't fit LED bulbs in the back becasue the hole is too small.
  19. jimjam replied to beerbaron's post in a topic in Naked
    M and P (MANDP.co.uk) do a wide range of complete graphics starting at about £30.
  20. Don't be frightened to ask lots of questions about what the seller has done to the bike. Ask them odd questions as well like how long does the chain last and how far can you go on a set of tyres.That way if they have ridden it hard and not looked after it you can tell how often they've had to replace them by looking at the mileage. Of course the engine has to sound good. Nowadays I would take someone along as well. After all a couple of pints can save you from a nasty bill. Let us know how the test goes.
  21. jimjam replied to yammie girl's post in a topic in The Bar
    I SPEND A LOT OF TIME THINKING ABOUT IT JUST HAPPENING! :roll:
  22. jimjam replied to yammie girl's post in a topic in The Bar
    My best pun spoiled. I was at a meet this weekend. We might be arranging another in the next few weeks down by Hunstanton.
  23. jimjam replied to Pete's post in a topic in General
    Sorry to hear of the loss. Condolences to his family
  24. jimjam replied to gingerluke's post in a topic in Naked
    Sounds like your 2 stroke sensor has failed Check your connections
  25. jimjam replied to skyline's post in a topic in General
    Yep me too. I found out by accident as well. I got so fed up bleeding the front brake that I filled up the rear and put it in the shed. Next day, tube was full with fluid and no air either.
