jock r1
  1. jock r1 replied to ringadingding's topic in Yamabyss
    You can't derestrict them because they are not restricted to start with. but The exhaust is worth replacing to get a little more noise and power.
  2. Don't think you will be able to get one for your bike, I had heard haynes were in trouble back then so limited the vehicle books they were doing. Clymer don't have it listed either.
  3. http://www.whitedogbikes.com/cgi-bin/ccp51...900F_L_Reg_1994 http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...em=170047016355 Thats the only things I could find, strange that most of the usual plastic makers don't list the 900.
  4. Halfords do them, in the motorcycle section. or amazon if you want it cheaper and don't mind waiting for it to be delivered.
  5. Are you sure you take it out in the rain.........it looks so clean.
  6. The main dealer should be able to order the parts for you.
  7. Have you checked the levels, they should be topped up to the max-mark. If you switch the headlights on, do the warning lights dim?
  8. You might want to think about getting one of these. http://www.secure-a-bike.com/prijslijst.html http://www.motosafe.co.uk/bikesafe-c19.html Or buy a house with a garage.
  9. jock r1 replied to kyler6's topic in Naked
    Have you checked it's getting fuel?
  10. jock r1 replied to 12noon's topic in The Bar
    Well done getting it sold. I had the same when I was selling my car which was a rare Peugeot 205 1FM. I got loads of idiots offering next to nothing but it sold for £3054
  11. jock r1 replied to stedeam's topic in Yamaha Workshop
    You will be needing a relay.
  12. Hi Rob Did you manage to get the airfilter changed, did you find it easy to do? Steve
  13. The fuel tap and the two fuel pipes are on the underside of the tank near the seat end of the tank.(you need to wedge up the front of the tank to gain access to the pipes) The hoses are each secured with a retaining clip - Just squeeze the clip with a pair of plyers to remove and then pull the pipes off. Might be an idea to mark one of the pipes with a bit of tape so you know which goes where when you are refitting them.
  14. They are easy enough to change - if you have a Haynes book it's all in there. Remove rider seat - two bolts remove fuel tank - unscrew front bracket, wedge tank up and then disconect fuel pipes (remember to turn the fuel tap off before removing the fuel pipes) remove rear bolt and lift the tank off. remove airbox belt clip on each carb inlet, lift the airbox out and then unscrew the bolts so you can seperate to two parts. Swap filter and then put it back together refit is reverse of removal If you have a steering damper fitted you will probably have to remove it first - to make it easier and avoid scratching the fuel tank. The R1 runs a dry airfilter so don't use oil on it. and remember to turn the fuel tap on again after refiting the fuel pipes. I would stick to the standard filter unless you are going for a dynojet kit as well Tools required are a couple of screwdrivers, spanner, sockets and a pair of pliers. You will also need a block of wood or something similar to hold the front of tank up. Steve
  15. jock r1 replied to eselway's topic in The Bar
    "allowed"What do you mean by that? A 125 is ok for short trips but I would go for a 600 if your planning on doing any serious miles.
