morepower
Everything posted by morepower
  1. Hi, Just changing my headers on my fzr400(night mare!) and looked at the exup on the exhaust and it's a mess. Only 1 cable attached and both are falling apart. 1) Should the valve move very freely? 2) When i pull the cables down to the exup they continue to come is tis correct? 3) Also does any body know where i can but some cables from? Cheers guys morepower
  2. hello mate thanks for the reply, i did check the link and it is o.k with no bends any other ideas? cheers
  3. Hey guys. having problems with my 2003 XVS 125. It will go into 1st gear but not any other gear, when i managed to get it into 2nd gear and back into neutral the engine will not start now. The gear problem came about because the gear pedal was hit from the front. Does any body have any idea what could be done to fix this issue-i.e if there is a linkage in the gearbox of some thing that would require replacing? cheers
  4. morepower replied to morepower's topic in The Bar
    Hey Gismo! thanks for the reply! the pads are half worn the disc is 90%. the hose's air o.k and there is fluid in the cylinder. i think it could be air in the system. do you know how to bleed it? cheers
  5. morepower posted a topic in The Bar
    Hi all, I have a 91' jap fzr 400 exup. it's great apart from the front brake does not work correctly. if you pump the handle the brake starts to work but once it has been used the handle goes all floppy again. there are no leaks. any body have any ideas on how to fix it?
