Howie69
Everything posted by Howie69
  1. Howie69 replied to mike aldron's topic in Naked
    Try a general search on google for this mod, if you look at where the wiring comes from the switch there should be a green wire,you have 2 options, follow this under the tank to a connector near the head stock you will notice that this is where the green wire ends. connect this wire to the free terminal on your headlight(right hand) and this provides dip beam. When you go to high beam it should switch the dip off. Or just splice the green wire where it comes from the switch and connect this to the spare terminal on the right headlamp. Use a ci$rcuit tester to make sure it is the green wire, it is on a 2006 fazer! Do not bridge from the left to right headlight or it will burn out the headlamp . Easy mod Good luck
  2. Howie69 posted a topic in Naked
    Help!!! I have a 2006 faired fazer 600 and above 80 mph i gat a lot of vibration through the handlebars, more so when 2 up does anyone else hve the same problem or even a cure
