01yzf600r
  1. Alright here is the problem i have a 2001 yzf 600r and i was going to go change my brake fluid. i got all of the fluid out of the front brakes and the resivior. so i went to put new fluid in it and now the brakes will not pump up no matter what. I tried to bleed them the old fashion way it didnt work, i cant get the lever to pump up. then i tried to put a hose on the bleeder screw and pump the brakes until bubbles stop comming out. the bubbles quit comming out but still no brake lever. then today i went and got a brake bleeder. i hooked it up and took all of the air out i thought it was working great. but still no brake lever pressure. WHAT AM I DOING WRONG!!!!
  2. well how do i fix it
  3. 01yzf600r posted a topic in Naked
    Ok here is the Problem i just bought a 2001 600r and i was changing the oil and everything when i decided to cut off the front turn signals to get some flush mounted ones. when i cut off the front turn signals all the back ones do now is flash fast and both flash when i turn on the signals like warning lights. i went to put on the new signals and they all flash like warnings when i try to turn the turn signal on. also on my bikes dash the turn signal indicator doesnt come on when the flashers come on. please let me know what the problem is.
