yzfsammy
Everything posted by yzfsammy
  1. yzfsammy replied to yzfsammy's topic in Naked
    blue pill?? im damn sure i read it on here, but i mite be goin crazy!! Ha thanks mate
  2. yzfsammy posted a topic in Naked
    Hi all, i know ive read it on here before but ive looked for half an hour and cant find it, soooooo... someone said that u can change the clutch arm (under clutch cover) for a longer item from another yam to make the clutch pull easyer!! i think it was a viagro or sumthing but i cant remember!! Thanks sam
  3. yzfsammy posted a topic in General
    HELP ME, they brought back the whisper, ive had about 7 in the last 3 days, im addicted HELP!!
  4. HA HA That did make me chuckle, nice one drepey!
  5. So does that mean that i just concentrate onthe one nipple untill ther are no bubbles and then move onto the second? well im waiting for my rear disc because of the damn postal strike, so ill give it a go when i get it! Thanks Sam
  6. Hi all, hoping someone could shed some light on the rear caliper of my r1, because it has two bleed nipples? is there an order on which to bleed first? i can happily bleed the front brakes with no problems ive just never bled anything with two nipples? And if anyones got an opinion on what type of pad works best on the rear, ie; std yamaha or uprated hh? Anyway thanks again y'all and ride safe!
  7. I had a 03 r6 that was restricted, i took it to a friend in a garage, it took him maybey half an hour to get the big washers out and 5 minutes to get the throttle stop off by from what i remember by bending it off! no damag to anything, and wow what a difference!
  8. i got white on mine blue 01 r1. looks cool! tried gold b4 that, looked okish but a little bit gay! make sure you get the tape thats in shorter strips rather than a roll, MUCH easyer to fit! Sam
  9. Cool if i get time i will try this weekend, but its me anniversary on sat so will get back to you and let you know!# Ta Sam
  10. Nah, i know the forks are good coz i bought them to rebuild the crashed bike, the original fork and yoke set up was fu**ked, cracked bottom yoke, clean snap down the middle of the top yoke, one bent fork with a broken caliper mount, and the top nut on the other fork was copletely ground away! The forks i wana fit were bought from partfinder from a low millage bike! but do you know if the 5jj wheel will fit the later forks? thanks Sam
  11. Hi all, i posted this in the sportbike section but got no replies, hopefully sum1 can help me in here! Does a 2001 front wheel from an r1 fit on the slightly later 02 model? Because im putting forks from the later bike on my road 2001 model but the wheel off my later model is bent as a boomerang! Any help would be great!! ta sam
  12. yzfsammy replied to mini_dachshund's topic in Naked
    yep, i agree coz i been doing the same! But now i wana hear some feedback about the BT015, and the other day i read that i think the new gsxrs will be coming on BT016's! But as far as the 014 goes, top tyre!
  13. yzfsammy replied to 03R6's topic in Naked
    Hi i got a 5jj R1 aswell so i know they need it, but the thing is i was on a tight budget so i found that a LSL damper + fitting kit only cost me about £130 instead of the £250-£300+ of the normal across the tank types! Ok to be fair its not a billion times ajustable like sum but i think its definatley a good idea as a starter kit to get used to the feeling of having a damper, i mean the first time i did 100mph+ with the damper wound up, it was like the bike was on rails!! GET ONE!
  14. yzfsammy replied to yzfsammy's topic in Naked
    DAMN IT, I wanna see but my work computer wont play da vids on youtube!
  15. Hi, i have used the bt014 on my old r6, r1 and my current r1 and think there are great! i was woundering about the bt015 myself if anyone has used them on a litre sports bike , id love to know what you think!
  16. yzfsammy replied to yzfsammy's topic in Naked
    Hi there, ive been riding for a few years, ive had an R6, fz6, wr450f,02 r1, and now this one but ive always been of more the fast road rider rather than a stunter! By the looks of it i think im just being a PU*SY with it, time to grow sum balls i guess, engine cage, 12 bar, wrap all the fairings in cotten wool and store them in the shed, so it will only be me that gets FU*KED when it all goes wrong! HA HA HA WISH ME LUCK Sam
  17. yzfsammy posted a topic in Naked
    hey all me again, just remembered i forgot to ask if anybody must know if the front wheel of a 02(first injection model) bike will fit onto the front of a 01 (last carb model) bike? thanks Sam
  18. yzfsammy posted a topic in Naked
    Hey all, this question has been floating round me head for a while, i realy struggle to get my front wheel up (01 yzf r1) when i bought the bike the forks had been raised through the yokes, of the top of my head by mabey 20-25mm, would this change in geomitry afect the bikes willingness to come up? The chances are this is my crazy imagination, but if anyone has either experience or a clue on the matter it would be good to have a chat Thanks Sam
  19. Ta mate, ill have a look and see what it says! Thanks Sam
  20. Hi all, as yamaha have used these awsome brakes on so many different bikes someone must be able to help! (i hope) How difficult is it to service the calipers, do you need a special service tool to remove the outer piston plugs(the gold spot bit) or can all the seals be changed with just the piston pushed back into the caliper?? If it makes a difference they are calipers of a 2003 R1 Any help would be great, Thanks Sam
  21. Hey all, as i am a bit of a ditz i serviced my k&n the other day on my 01 R1 and just followed the instructions, cleanong the out side of the filter and re oiled the outside but it wasnt till i was putting it back together when i realised that the filter works from inside to out, so does that mean ive done it wrong? If anyone could help it would put my mind at ease! Thanks Sam
  22. Hi all, im new here so helllooooo to all and hope you are well, Im after a bit of help and want to know what everyone else thinks! My 01 R1 is now on 19000 miles and is rather stone chipped ive decided i want a respray. Now the question is do i get it resprayed in the original blue or as next year James Toseland is in motogp on a yam, do i wait and get the tech 3 paint job?????? I keep thinking to myself, do i dont i because the bike in the blu makes me go weak at the knees everytime i see her (Rachel is her name)! HHHHHHEEEEELLLLLLLLLLPPPP!!!!!! Thanks Sam
  23. Hey all, was woundering if anyone could help me, im slowly rebuilding a 02/03 yzf r1 but my road bike is a 00/01 that is on 19000 miles now so is need of the suspension refreshing, ive been told that the rear shock will swap straight over and is a plus because the later shocks are a better, but i wana know how much work it is to make the later yoke fit the earlyer bike? if anyone can help it would be much appreciated.
