contrabandit
  1. lead replacement additive and a mixture of 20-1 would probably solve your problems
  2. just a bit it's like comparing a shovel to a JCB and asking what the main difference is , aJCB can handle a lot of dirt and can really shift it where as a shovel can only handle a bit , is slow and hard work.
  3. contrabandit replied to Raster's topic in The Bar
    you have to allow for the oil filter being empty of oil after an oil change especially if you changed the filter as well , which is allways reccomended to do so, or the clean oil is just running through a dirty oil filter.if you run engine the filter will fill with oil and the level will go down.
