yoda
Everything posted by yoda
  1. yoda replied to drewpy's topic in Yamabyss
    Drewps, you need a vacation!
  2. yoda replied to growls's topic in Yamaha Customs
    Sounds more of a clutch problem. Check that first.
  3. yoda replied to cool uncle's topic in Naked
    It doesn't tell you what the problem is? It could be that the sensor has failed
  4. First it could be fuel starvation, so clean the tank out and the petcock and lines. Secondly, if you have diaphragm carbs, it could be caused by a hole in the diaphragms. What ever it is, it most certainly is fuel problems.
  5. yoda replied to Heather's topic in Naked
    Diablos, by the devil they are good!
  6. yoda replied to peteypops's topic in Classics
    You have a fueling problem.
  7. yoda replied to bananaR6's topic in The Bar
    There are several specialist shops on this subject and they sometimes advertise on MCN which is out on Wednesdays. I know of none in Scotland.
  8. There are so many things this could be that without a full dyno test, I would not guess the outcome. Anything else that it does?
  9. Don't run it with all that oil in it. You won't like the result.
  10. yoda replied to Goff's topic in General
    Does my bum look big with this?
  11. Not unless the sockets are the same.
  12. yoda replied to simondlh's topic in Yamaha Workshop
    The counter head needs servicing. It is trying to screw itself completely around the clock.
  13. Brilliant!!
  14. I know at this time of year that it is time to customise wood and nails but does Foamy know this?
  15. yoda replied to drewpy's topic in The Bar
    By the time rainex has made the visor hardened, it would be time to change it anyway!
  16. yoda replied to mrbump's topic in Yamaha Customs
    It really does sound like intermittent fuel blockage. It's the egg in the tank syndrome. Its OK for a few miles as the egg is dragged down by the fuel flow and then it blocks the outlet and stops the engine. Soon as you stop, the egg has floated to the top and away again you go. It must be in the tank.
  17. Kick starting bikes is OK if the timing is spot on. Check the whole ignition system.
  18. Buy a real flat tracker you idiot!!!!
  19. Analogue speedos driven by cable work on a drag cup principle. The cable turns and a magnet rotates in the head moving a cup with the needle on it. If the cable is located and the speedo does not turn with it, then you need a new head.
  20. OK I suspect that the engine breather tubes are blocked and as the engine crankcase pressurises, its blowing oil out or past the piston rings and burning it. If the casings are clean and the rear of the bike, it must be burning oil. You might find some in the airbox, so clean it, ride it and check again. Clean all breathers first.
  21. Need a new cable.
  22. I assume you put oil in it?
  23. Choke off, warm engine. If the knock will not go away and appears to be at the top of the engine, it is probably little end knock.
  24. yoda replied to enduro100CC's topic in The Bar
    It needs running in. The loss of power when accelerating is probably the float height of the carb. That assumes that the timing is spot on. You also need to check that the fuel tank and petcock are clean.
  25. yoda replied to S.Wessels1's topic in The Bar
    The temperature sensor has failed or the wiring. There might be a fault code on the speedo.
