yoda
Everything posted by yoda
  1. There is no need to block out your L plates. You are trained to a higher standard than the L plate, so you can even carry passengers with the plate on. Next step up is a new 250cc as the engines are now 4 stroke and produce 30 hp. They are alot cheaper than the 600's which need to be detuned. Expect to pay about £3500 for 2008 models.
  2. The battery acts as a buffer for changes of load. Therefore the engine load remains much the same. When drawing load directly from the electrical generator on the engine, any change in load will affect the running of the engine. It should not make any difference whether the earth (ground) has ac or dc or a mix of the two if the connections between the engine/gearbox, battery and frame are good.
  3. yoda replied to pnoidrummer's topic in Naked
    You are just so got to get a bigger bike Amanda!!
  4. yoda replied to fifer's topic in The Bar
    You deserve a medal for the ride to work and back on such a small machine. Must be economical!!!!!
  5. You would need special sheet metal tools to knock the dents out. Go to a sheet metal working establishment and offer someone a little money. The work must be done from an internal anvil and planninshing hammers on the outside. The alternative is to rub down the tank and fill. Finish off with a total repaint in your colours.
  6. Do you have to buy a bike this size? A 650cc would be more suitable for your power to weight ratio. Pass your test first and then decide.
  7. yoda replied to pnoidrummer's topic in Naked
    There will be a 2008 version of this bike out soon.
  8. You can measure the voltage at the terminals. Clean up the engine /frame ground and ensure that the terminals are tight. This will ensure that there is maximum charge for thew battery.
  9. True, could be badly worn piston rings etc. To find out, have the compressions checked on all cylinders.
  10. yoda replied to jskf16's topic in Naked
    Brings a new meaning to 'India Rubber' How about Grecian 2000 Profs. Burnout the streets of Greece!
  11. yoda replied to mellon1989's topic in The Bar
    It's all very well having an extended motorcycle test due to higher incidences of riders injuries and deaths but what about the car drivers that cause most of them? I believe that all drivers except disabled should spend one year on two wheels and have to pass a test before they can apply for a car licence. That would reduce accidents. I would also remove the right of foreign drivers to be able to drive on UK roads for more than one month without taking and passing a written test and then a full driving test after three months.
  12. Check the earth on the engine/frame and battery connections first. These should be good, clean and not loose. Always check the lowest common denominator first!!
  13. As it's the elk season, I will not help you.
  14. yoda replied to pnoidrummer's topic in Naked
    You can kill or maim yourself on any bike, the more powerful, the quicker. Do get used to the roads and riding on a 250cc first.
  15. yoda replied to Mtrimmer's topic in The Bar
    interesting ride for you lot to join up!!
  16. Oil in the airbox can be caused by several things. First wheelies cause all sorts of problems such as this. Second, blocked cranckcase/head vents. Third overfilling with oil. Why did you put that oil in it?
  17. Custom parts are always available from the USA first. Do an internet search.
  18. yoda replied to Josh's topic in Naked
    With that sort of problem and taking into account the age of the bike, I would think that the cost of changing the rear shock was worth it. Wish I had thought about the rear end. All is not what it seems to be!
  19. yoda replied to Watto's topic in The Bar
    Welcome to the affray! Think you should get about 46 miles to the imp. gallon.
  20. Welcome and I think you mean 'meet up' as what you wrote has other meanings.
  21. If your cylinders 2&3 are constantly oiling up, I suggest that it is time for a strip down. You will need to replace, at the very minimum, the piston rings and valve seals. To give it a full overhaul means new pistons and rings and new valves and guides etc. This has probably happened because the centre cylinders run hotter than the outers and there is more wear. Just a thought. Check all of the crankcase breathers for blockage. If the crankcase starts to pressurise then the oil will blow past the piston rings and valve guides..
  22. May stardust line your route!
  23. yoda replied to YamaHead's topic in The Bar
    The lake might look like the Med. but the water temperature doesn't get much above freezing.
  24. yoda replied to david1950's topic in The Bar
    Generally speedos read about 10% more. This also ups your milage. So if yours is reading low then you must have bigger wheels on your bus!!! It might be paralax error, as I cannot remember if the speedo is digital.
