yoda
Everything posted by yoda
  1. yoda replied to twidge's topic in Yamaha Workshop
    Why if there is one, do you think that it would read mph and then add the distance in kilometers?
  2. It is possible that part of the wiring loom is shorting out on the frame or engine. The wiring might be within the engine at a part that expands with heat. You should check that the battery is OK and all of the earths (grounds) are in good condition. You do not state which fuse or on which circuit it is. Something is drawing too much current.
  3. yoda replied to twidge's topic in Yamaha Workshop
    It is a cunning and deliberate ploy by manufactureers to make you think that you get good fuel consumption. The odometer and speedometer are not allowed to read under so they are made to read over. Most read about 10% over therefore you milage will read over. In your case, assuming that you have not forgotten that you topped up the tank somehow, it does sound excessive. I would check it again.
  4. It probably won't notice until you reach an extreme point in riding, and then you'll find out very quickly.
  5. yoda replied to HarryH's topic in Classics
    Just to warn you that unless the following has been done or the bike has been used regulary, the fuel tank and filters will requre cleaning and all of the oil will need to be drained, flushed and refilled with new. Apart from that, I hope it's a bargin!!
  6. Sorry, can't help with that. Suck it and see!
  7. For kick starts you need a very clean plug of the right grade and good ground (earth) to the engine/, engine/frame. This ensures an electrical path. Kickover start voltage will be low so anything you can do to enhance this will be good.
  8. You sad bugger. I bet you would like to keep Trebants running!!!!!
  9. I would be worried more about the streightness of the forks you intend to fit. If the wheel is that bent, why do you want to fit those forks?
  10. yoda replied to jrhendryx's topic in Classics
    Difficult call on this one. How about 'on condition' and by that I mean if they are not leaking gas or oil, they should be ok. Then if they have done more than 50,00 road miles, they probably need changing. Heavy loading will also require you to change them more often. Off-road work will require more frequent changes. Spring length unloaded must be the same and any preloading must also be equal. Copout is to refer to the manual.
  11. The adventures of Ying Ting Ting!!! Looks OK, good luck.
  12. Please don't run low on fuel on an old bike. All of the rust and crud gets sucked through, blocking the filters, punps and oriface. It's just not worth the hassle.
  13. yoda replied to Moxxberg's topic in General
    Very sensible Andy. Keep it up. I have also driven (car) around the top of Scotland and it only rained a little but it was early June. Clear skys, sunshine, warm and no Scotish midge.
  14. yoda replied to mat-earl's topic in The Bar
    The bumff says not to get the remote control wet or crash it heavily. 'Nuff said!!
  15. yoda replied to CaptainFlack's topic in Classics
    I think that tyre width will be the problem.
  16. Apart from a whole host of other fuel/air ratio problems, you might be running a too hotter spark plug. Go for a cooler grade and then find out what colour it is. The higher the number, the hotter the tip.
  17. yoda replied to smithac87's topic in Naked
    Funnily enough without reading the next message, I was going to suggest Mobile 1. The reason for this is that it was the first readily available synthetic oil outside of the aviation industry. It has been around along time and I have never heard a bad word about it. There are many oils around and some are highly specialised, that might be better for your personal use but at the end of the day M1 is a good all-rounder. In everyday use, your bike will be happy with any oil but it is the extremes that cause a problem.
  18. yoda replied to david1950's topic in The Bar
    When running in it is best to not rev the engine too high but also not to load the engine at low revs.
  19. yoda replied to Mattinky's topic in The Bar
    Have I missed something? Can we have a definition of cagers please. It lost something in the translation.
  20. I think that you might be able to register using the identifyable engine number. This will give you by date of manufacture a non Q plate. Try using a pencil and paper tracing method on the frame number area. If you can get most of it, the manufactureer might be able to help with the rest.
  21. I would get a black round one and pay as much as possible for it. Now does this answer tell you something?
  22. Picture says Kawasaki on the crankcase, so what's this all about?
  23. Why are the bike prices higher in Spain? The bikes are sold cheaper from new and most are not looked after properly.
