yoda
Everything posted by yoda
  1. Yes, just tidy the fins up with a small grinder. There is nothing else apart from replacing the head. The loss of fins will not make a big difference to the bikes performance as long as a fairing is not fitted.
  2. yoda replied to a post in a topic in Yamaha Gallery
    Certainly the side fairings will look great, they are about £300.
  3. Simple answer no. Drawing more power will increase the amperage on the cables and the switch. This could cause a burnout. You would need to fit heavier cables and a heavier duty switch. Try to find a different type of bulb with the same rating as is now fitted.
  4. I think it must be fuel starvation then.
  5. Cooling requires forward movement ie airflow though ther radiator. If your sitting still at idle the temperature will go up.
  6. yoda replied to sumncguy's topic in Naked
    Buy a cruiser and then complain about the high gearing! Fit smaller wheels!!
  7. Does this spluttering happen at any steady thottle speed or just one part of the band? This could be a problem with the advance/retard electrical timing.
  8. yoda replied to XTreme's topic in The Bar
    If your in the admin group of this forum, would you remember to limit you enthusiasm of using swear words when you post.
  9. yoda replied to bdgaf's topic in Yamaha Workshop
    If you have a weak spark in open air conditions, it is quite possible that it will not spark under compression. Also if its sparjing without being grounded it must be grounding on the outer of the spark plug lead. For a good spark you need a good earth.
  10. yoda replied to dizzyfish's topic in The Bar
    Welcome to the forum. I hope you enjoy your 'new' toy!
  11. yoda replied to kinder's topic in The Bar
    Your turning the engine the wrong way.
  12. yoda replied to trebloc's topic in Yamaha Workshop
    I suppose that the carb for that cylinder has some fuel in it?
  13. yoda replied to trebloc's topic in Yamaha Workshop
    It cannot be firing on that cylinder. If the exhaust is cold then there is a fault. Take the plug out and ground it on the engine, then when turning it over see if there is a spark. Don't hold on to the plug to do this. I suspect that there is no spark and the plug lead is faulty. Spark plugs are also known to fail.
  14. yoda replied to motoman21's topic in Naked
    Put some fat weight on and go to sleep until the butter softens.
  15. yoda replied to Beckie's topic in Yamaha Workshop
    You haven't damaged that new black beauty have you?
  16. Fuel starvation could be causing this as well as any air leaks from the carb mountings. Sticking float or wrongly adjusted needle or jets. Air leaks from the throttle butterfly spindle or slide will also cause weak running.
  17. yoda replied to a post in a topic in Yamaha Gallery
    Your picture will not load on my browser IE8 so can't see it!!
  18. It's probably fuel starvation. You need to clean out the whole fuel system.
  19. I have no problems with Ducati mechanicals as such but I would take issue about their electricals. They used to be terrible.
  20. See my answer above.
  21. Why bother. It will be right again in six months!
  22. The quickest way to increase the acceleration of your bike is to change the rear sproket. This will reduce the top speed but so what.
  23. yoda replied to Andy Jeffries's topic in The Bar
    Welcome to the frey Andy! The answer to your question is yes. You can fit the Fazer one or there are others. Anything to help keep it cleaner!
  24. yoda replied to pazaryan's topic in Naked
    Unless you can see a leak or smoke from the bike, its normal use. I would give the bike a long ride once a week to get everything hot and charge the battery. That might sort out the oil use.
  25. yoda replied to rescue76's topic in The Bar
    I had full-blown exposure once while riding. My core temperature went right down. It was a bad experience. Dont let it happen to you.
