yoda
Everything posted by yoda
  1. yoda replied to eyedee's topic in Yamaha Gallery
    Yamaha do make very pretty machines.
  2. yoda replied to YBRLondon's topic in Yamaha Workshop
    When the bike has been left ie that it is cold, the oil would have drained back to the lowest point. In most cases that would be a sump. Therefore a sightglass will give one reading. If the bike is run for a few minutes and then stopped,you will get another different level. The point is to get consistancy. If it is not mentioned in the handbook, then choose to check the level when cold. Do not overfill.
  3. When you wrote to say that your petcock was leaking, why did you not write and tell us that fuel was leaking out of the carbs. That is a different story to a petcock leak. Fuel is leaking out of the carbs (how many?) because the float is not sealing off the inlet That is a seperate problem to a leaking petcock
  4. There is a market that most people forgetabout, and that is ebay, international. I am not here to recommend that product but it might pay you to think about it. Very good luck.
  5. FZ6
    yoda replied to dkratz's topic in Naked
    Handlebar buzz should not happen on modern bikes but if it does then the manufactureer should be notified. That is a fault, and is unacceptable. However, sometimes in part of the rev range the bars might resonate in sympathy with the engine and this should be dampened down by changing the engine mounts.
  6. Looks great and I take note about the Yamaha top box.
  7. yoda replied to tommy83's topic in The Bar
    How will you get it through the MOT?
  8. Mark, get Jen to smack your botty. You wrote nothing about soaking the bike with water before it started to conk out. Waterproof the electrics with WD40 or similar next time, before you hose it.
  9. yoda replied to tommy83's topic in The Bar
    Assuming that the baffles are still fitted, then no but it might be a little lean on the mixture. Most exhausts are for looking not performance.
  10. No not really. I guess you can ride them!! We have bikes though!!
  11. You probably have water in your fuel system so any anti icing agent would work but be careful that it doesn't rot rubber seals! Better off draining the tank and carbs, cleaning them and refilling with fresh fuel. I cannot advise you to put anything in your fuel tank other than the correct grade of fuel.
  12. I used to cover the engine of one of my cars with a horse blanket. That worked. If you can keep the frost off, all good. I would still be worried about this particular problem though. The carbs will ice up as you drive but there should not be any moisture in the airbox anyway. Sometimes they will do it in fog.
  13. If your throttle actions starts to go flat then you know it's started to ice up.
  14. This could be carburette icing. It could also be water in the fuel freezing in the carb. If it only happens when the air temperature is below freezing or close to freezing then it must be carb related.
  15. Sounds like the carbs need an overhaul. The choke mechanism is sticking and overfueling.
  16. Assuming that you have some coolant in it (check the level cold) then it could be that the temperature sensor is not working properly. I dont know if the fan signal is from the guage needle or has its own sensor but you need to check. Another thing to check is that the radiator fins are clear and not blocked to the airflow.
  17. It's overfuelling with choke on. Dont open the choke fully.
  18. yoda replied to Moxxberg's topic in General
    We've had all that weather in one afternoon!
  19. yoda replied to delchip's topic in Yamaha Workshop
    Well what else doesn't work?
  20. The engine has a sealed breathing system and will deposit the odd bit of oil in the intake area. There should not be much but if there is, then there is a problem with blocked breathers or within the engine itself. If it wasn't a Dragstar I would have said that someone had wheelid it too much. Clean the intake and fit new filters and change the oil. Check it in 500 miles.
  21. You need to do some more riding. You do not need a tacho to change gear.
  22. yoda replied to gav2k's topic in Yamaha Gallery
    Sorry! Should have remembered that when I wrote it.
  23. yoda replied to gav2k's topic in Yamaha Gallery
    Stop spreading rumours. After passing the UK test, you are limited to 33 hp until the age of 21 when power is unlimited.
  24. yoda replied to stevie9183's topic in Classics
    Thank you for using the correct spelling!!!!!!!
  25. yoda replied to stevie9183's topic in Classics
    First advice. Don't buy a Virago 535........just kidding. Good luck and spend plenty on the chrome.
