yoda
Everything posted by yoda
  1. yoda replied to Goff's topic in The Bar
    Hi Lisa and welcome to the site. Soon be spring!
  2. The point is that the engines are designed in Japan where they don't have Redex so its never been tested on them. If you wish to shove something up the carbs and engine, then find something that Yamaha have tested as to not causing any problem. Carb icing is caused by the venturi in the carb and in a standard configureation, should not happen.
  3. Could be a whole host of problems but if it was working before being stored it rather narrows it down to fuel. Probably water in the fuel or sticking floats or blocked fuel filter/line. Clean plugs and charge the battery and drain all of the fuel out. Put in fresh fuel and ensure that its in the carbs, try to start it. Oh and welcome to the forum!
  4. Do they have Redex in Japan?
  5. yoda replied to TeamBPR's topic in General
    The damper is there to stop shaking at high speed. Some bikes tend to have steering occilations that get worse the faster they go. Dampers have been fitted to bikes for a very long time.
  6. Hi!
    yoda replied to TeamBPR's topic in The Bar
    Hello and welcome. Good decking, shame someone stood a bike in the way! Have fun.
  7. yoda replied to R6Gale's topic in The Bar
    It's a matter of opinion. Your choice.
  8. Hi, welcome and agreed
  9. It should spark before top dead centre. Check and see if there is continuety between the outside (ground) of the spark plug when fitted and the engine. The needle shoud be hard over otherwise that might be the problem. Also check the engine to the battery neg side and again it should be hard over. No resistance between any of them.
  10. Hello and welcome. This appears to be a loose battery lead or earth lead problem. Check all leads. Also check the kill switch operation.
  11. yoda replied to R1cky's topic in Yamaha Gallery
    No that's R1cky in disguise!
  12. yoda replied to fadge's topic in The Bar
    Hello and welcome to the bun fight. I'm joking!! Hope you find this forum interesting.
  13. yoda replied to rodds1's topic in The Bar
    What is the voltage across the battery terminals when the engine is running above idle?
  14. It might not be so straight forward to look at. You need to check for any play between the the rotor and the shaft. Any play change the key.
  15. Yes but when we get bored we go to Switzerland, (over the water) and do some switchback hills. No pillions allowed.
  16. Does my bum look big on this?
  17. yoda replied to Matt Hillyard's topic in General
    Why ruin its good looks? On the other hand give me £10,000 and i'll do it.
  18. That would make a very good dog bike.
  19. HI
    yoda replied to scotty's xj600's topic in The Bar
    Hello and welcome. Fix that clutch!
  20. yoda replied to scotty's xj600's topic in The Bar
    Worn clutch or gear synchros is all possible. Try adjusting the clutch.
  21. yoda replied to R1cky's topic in Yamaha Gallery
    46 is a credit to you. Very nice!
  22. I cannot help with the ignition electrics, as I do not have a manual for them but one thing you can easily check with a multimeter is continuity. You need to check from the centre electrode of the spark plug, when connected to the lead, to the outer of the lead. If there is any electrical connection at all, change the plug lead as your losing sparking voltage. This can also be intermittant so wiggle the lead to see if there is any difference.
  23. Could have been a partial siezure. These free off when cold so will turn over again. The sparking is normal and is just taking the closests high spots off. You might have a weak spark that is not firing under compression so test the rest of the circuit.
  24. yoda replied to big no's topic in The Bar
    Hello and welcome. Good luck with the project. There's lots of help on here!
  25. If you mean teens in degrees F then thats the battery voltage down. I think thats your problem.
