yoda
Everything posted by yoda
  1. White wall tyres are fitted to Harleys so they must be readily available.
  2. yoda replied to antfzr's topic in General
    Your nearest track.
  3. Is the tank vent blocked?
  4. yoda replied to Yamaha_R125's topic in Naked
    He meant no heavy braking, acceleration, stoppies and wheelies. The chords in the tyre have to bed in and while they do that the tyre gets hot. Premature failure can and does happen if the tyres are not run in.
  5. yoda replied to Airhead's topic in Yamabyss
    Come back and give us another joke.
  6. yoda replied to Airhead's topic in Yamabyss
    Sometimes Oldgit, you go too far!!! Collect your hat as well.
  7. yoda replied to schulz476's topic in Classics
    Your not getting enough fuel in for big bangs.
  8. yoda replied to mikenunan's topic in General
    Welcome to the forum! For bike seat comfort, only you can tell whether it is right. If you live in a mountainus region, you will need a bike with alot of torque (Nm) so two up on a fz600 would not be ideal. I suspect that a 1000 cc bike might be what you need.
  9. Try scewing it in first and then out. Also heat the casing that the bolt goes into while turning the bolt. Failing all drill it out, carefully.
  10. Oh dear! Well can't be helped. Better luck next time!
  11. Think you will have to change the indicator relay. The contacts on one side are not working.
  12. I think that you will need to buy another one as well for the bits and pieces that you will need.
  13. There are three ways to get more power from your 125. Turbo supercharging, NO2, high performance petrol. All are expensive so forget it.
  14. Try bending it back abit.
  15. yoda replied to a post in a topic in General
    Nice one on ebay for £3000, inc. kit.
  16. Does this happen at any engine speed and does it happen at a constant throttle setting?
  17. yoda replied to a post in a topic in General
    Kawas e6f is neet and petite for the little lady and probably the best bet due to weight. Suzuki Bandits are heavy and the seat height is just a little too high even on the lowest setting for her. Look in MCN for seat heat adjusters.
  18. Have you changed all of the spark plugs? If so then you need to change the engine management system. Before you do that, take it to a dealer and get it computer checked.
  19. yoda replied to Airhead's topic in General
    Scary, very scary
  20. yoda replied to xs360's topic in Classics
    You might make it a cafe racer but try and stop it!!
  21. Try using some washers as spacers on the mounting to clear the frame.
  22. The exhaust should clear the frame and everything else. I think your m,otor is going to run very lean and hot. You might also need to change the spark plug.
  23. The valve stem oil seals, if fitted, need to be replaced or the valve guides have worn and need replacing. That is causing your oil consumption. With your mis-fire as well, do you really want to keep this bike or let the dealer sort it?
  24. yoda replied to Goff's topic in Yamaha Customs
    Sad problem but nice pipes. Remove leg and think of England!
  25. I think that you will have to ask a dismanterlers for one Try looking in MCN.
