yoda
Everything posted by yoda
  1. Would you like me to supply you with the bike in component form?
  2. PM me with full details but Mr Oldgit might be your best bet for a quicker return.
  3. yoda replied to pocketrocket40's topic in The Bar
    Check your advance/retard is not the problem.
  4. I'll contact some friends.
  5. yoda replied to Airhead's topic in General
    I'm not sure if you mean a gap year to uni. but I think that when you get out of the learning regime it can be very hard to restart.
  6. Go for the ABS, it will give you a bit more security and when the time comes, perhaps enhances the sale.
  7. You should also check to see if the ring grooves on the pistons has opened up allowing too much ring movement.
  8. Onyer bike.
  9. You could try turning your bars upside down.
  10. yoda replied to lukey's topic in Naked
    Yes you are stupid. Now grow up and eat your soldiers
  11. yoda replied to stevie g's topic in Yamaha Customs
    I still do not know what a 'park' fuse is. However, if the fuse blows when you rev the engine then there must be a short in the main wiring to earth. You must check all of the wiring.
  12. yoda replied to pocketrocket40's topic in The Bar
    Welcome to the frey! You can use a 10 winter/40 or 50, what ever is available. This should be mineral, I believe. Why do you think your bike is running hot? There are two reasons for running hot, one is retarded ignition and the other is weak fuel/air ratio.
  13. yoda replied to stevie g's topic in Yamaha Customs
    What fuse?
  14. There is no law on carrying pets on a bike. They might say your load is insecure but if the dog is strapped on, then OK. It is quite normal in other countries. You should not let your dogs eyes get into the airstream as they will be badly affected.
  15. You need to take the plug leads off and clean the plugs as well.
  16. Conversely to all these suggestions, you could try not turning the bars.
  17. It's called a rich cut. The carb is overfuelling so needs a service.
  18. I think when you click on the link it takes a snapshot . Is this because its address is ending with jpg?
  19. Blown a fuse?
  20. You should have cleaned the calipers before fitting the pads. You will also need to clean and lubricate the disc bobbins so that the disc if free.
  21. You should see a big fat spark with no compression. Under compression it is harder for a plug to spark so if its starts weak then there won't be much to run the bike. Check that the engine ground to battery is good and that the plug caps are clean.
  22. yoda replied to g-funk's topic in General
    That's a truely awful dream. Take more water with your pop!
  23. yoda replied to jonnie's topic in General
    There are quite a few fazer 600 owners on this site but you won't catch them at week ends.
  24. yoda replied to tigger's topic in The Bar
    That modification found by Goff is easy to perform and looks like the answer to the problem.
  25. yoda replied to Alex's topic in General
    Hi and welcome back to a lesser civilisation. There is a well trodden path up Everest so you won't get lost.
