Yamaha V75 wiring problem
Both wires are the same size. The rectifier is missing, I’m having a job finding one, I think one of the red wires goes to it. I’m not sure how to upload a photo from my library. Do you think any 6v rectifier would do the job? Thanks
Hi, many thanks. I do have a Haynes manual but I don’t understand the wiring diagram. I’m not sure what red wire connects to the + on the battery.
Hi, please can a fellow owner either explain where the different battery wires go or better still, share a photo. I’ve just noticed there’s no rectifier on the bike so I’ll need to order one. At the moment I know the - goes to earth but I’m not sure where the + goes. The bike has two red and one white wire with bullet connections. thanks in advance
Yamaha V75
Hi and thanks for replying, the negative wire from battery has a male bullet connector on the end. There is a white wire coming from the loom with a female connector. Point taken regarding posting. Thanks
Yamaha V75
Me again! As I was tinkering earlier, the battery fell out and the cables got disconnected. The + is easy but what colour does the - connect to? There’s a white or a red. Also, I reconnected what I thought was the low oil warning light block, this is located near the oil tank. Once started, the horn stayed on. Slowly getting fed up! Thanks in advance
- Yamaha V75a
Yamaha V75a
Hi and thanks for the reply. I will look into getting the oil pump working. One other thing, do you know what the fuel tap positions are? It shows “on” , “res” , and “pri”. It seems to start and run better when on “pri”
Yamaha V75a
Hi and thanks for adding me to the group. I have a 1978 V75a, is it ok for the oil pump to be disconnected and run on pre mix? Pump already disconnected before I bought the bike I wasn’t sure if the oil was spraying directly into the internals. What is petrol/ oil ratio? What is the correct spark plug? Thanks
Meatballs
Joined
Last visited
