ducanao
  1. Running rich vs lean depends on your bike’s air-to-fuel ratio. A stroke bogging or gagging down is the primary indicator that you are running lean. When you open the throttle, the engine will stall for a time before returning to a normal idle. It will make an odd noise when you start off, it shows that will bog and then abruptly hit hard.
