mozpdragon
YOC Member
Everything posted by mozpdragon
  1. hi drewpy have you had any luck finding the carb bodys
  2. Hi drewpy that would be great if you have some carb bodies I'm mainly after the number three carb body as its cracked.
  3. Hi I'm having problems with the carbs that I have on my 1991 xj 600 when stripping the carbs to put them in a ultra sonic cleaner one of the carb body's cracked. Now I'm having problems getting a replacement set could I fit a different set of carbs from a different model bike
  4. The exact model details as Yamaha XJ600 1991 3KM5 EUROPE 213KM-300E2 What rear shocks can I use on this bike
  5. Hi I'm wondering if its possible to change the rear mono shock on my 1991 xj600. is there a different model shock that will fit to my bike that is cheaper than the ones listed for my bike.
  6. I have found a full carb rebuild kit on ebay with the diaphragms for under £26
  7. Hi I have a xj600 pre diversion 1991 the diaphragms have gone crispy. I have not been able to find replacement diaphragms could I use the diaphragms for a 1992 xj600 diversion as I can get them easily, will they fit my carbs
  8. thanks for that info will have a look tomorrow fingers crossed to works will let you now if it works
  9. Hi I'm having a little problem getting the xj600 90 reg started, I'v got the engine turning over with good compression but no spark. I have checked the coils and the pre pick up and all the wiring they are all coming back with the correct readings. could it be a fault with the clutch or side stand switch or even the ignition switch. Any help would be helpful.
  10. HI just wondering if I could fit a later ecu unit into a 1991 xj600 pre diversion to resolve the starting issue
  11. Hi finally after a year of fault finding and replacing the wiring loom after finding a mouse had made a mess of it and replacing other parts. I havejust got the engine turned over under its own power. Now to get it ready of it's MOT
  12. Hi I'm having a problem with my xj600 "91reg" I've had to repair some wiring as a mouse has eaten some wires while its been off the road over the past 12 years. I have replaced a few parts on the Starter wiring and all i'm getting is the oil light and nothing else no clicks from the starter relay. Does anyone have any ideas where else to check or is it the ecu unit that's the problem.
  13. Thank you for the helpful information will keep updating how I'm doing with this project
  14. Hi I'm after some help and advice as I'm in the process of putting my XJ600 back on the road after 12 years not being used. I've got a new battery fitted and most of the electrics seem to be working but when I try to start the bike all I get is the oil light coming on which is expected but nothing else happens. I have found some cut wires which maybe from mice so I'm in the process of tracing all the wires in the loom for anymore damage. Any advice or hints/tips would be grateful
