BlindSight
  1. BlindSight posted a post in a topic in Classics
    so my 1990 xs400 is running ok now (still need to clean the carbs and fx the electrical problem)...any ideas why it wont shif into anything but 1st and neutral? Should I just assume its the tranny and going to be an expensive fix? Suggestions?
  2. BlindSight replied to BlindSight's post in a topic in Classics
    No problemo, glad you got it running right. yeah I think its electrical, im sure the carbs need a good cleaning but after 2 days of riding it for about 45mins until it dies...not being able to restart it until it charged for a couple of hours...and then after a good charge it starts right up and runs for awhile...pretty sure its the alternator...will probably just ebay the parts. im hoping that the not going over 6krpm is just the carbs need to be cleaned, it was sitting for almost 2 years. still dont know what to do about the clutch issue though. anyone with pictures of how there cable is run with straight bars?
  3. BlindSight replied to BlindSight's post in a topic in Classics
    well I had bought a brand new clutch cable, there aren't any major curves or anything but it curves more than id like...anyone with straight bars have pics following the cable from the bar to the case to show me how its supposed to run?
  4. BlindSight replied to xtonyx's post in a topic in Classics
    ok so the tires are rear MT90-16 74H and front is120/90-18 65H
  5. BlindSight replied to BlindSight's post in a topic in Classics
    after messing with it yesterday im leaning heavily towards it being an ac generator problem (darnet I need to go buy another dvom :-/)...after it died I was having problems getting it started again and wouldnt stay running but I stuck it on the battery charger for a few hours and when I went outside it started first try and ran for awhile. so if I test it and the generator isn't charging the battery properly what should I replace and how hard is it? Also I noticed it wont rev over 6krpm, once I get going it will climb to 6 and if I dont let back on the throttle it will start to bog down a little bit. Also I can get it into first but it doesnt want to shift up to 2nd, I switched to a straight bar and the clutch cable is run kind of funky so it is really hard to squeeze the lever but even squeezed all the way back it doesn't want to go into any other gears, any suggestions on that one? THANKS FOR ALL OF THE HELP
  6. BlindSight replied to BlindSight's post in a topic in Classics
    OK so cleaned the cabs up a bit, and added some b12 fuel system cleaner to the thack, I got it started and adjusted the idle all the way up, rode it around a bit and it stayed idling in my driveway for about 30 mins this time before it died. any suggestions now?
  7. oh and I forgot to say..... fonzie rode a triumph.
  8. Ill admit im only 21 so I cant go into all of these old stories about the past but my automotive professor taught me alot about the history behind harleys...it started off a long time ago when one of his mechanics in his shop was working on one as a sideproject and when he quit he left the bike there...for months mr fant(my professor) tried to GIVE the harley away but noone would take it so he ended up throwing the bike into the dumpster.....import bikes had always dominated the marked as good, reliable, affordable, comfortable bikes in comparrison to the harles at that time that were cheap and constantly failing....from what ive heard the only way harley ever made it was because the hells angles bought them because they were so cheap to find one used and unwanted by anyone else...and now that they chose to slap a wayyyy overpriced msrp on the sticker and promote them to all of the "going grey" mid-life crisies people of today...they are buying them up like vetts...just look around you...just like vetts, at least 95% of them are owned by middle to upper class males over 30...they have come a long way but they are still a modern status symbol. I appologize to anyone who rides a harley taht doesn't fit in this category but you do have to admit that your fellow harley owners arent quite as "cool" as the used to be. Just my 2cents
  9. BlindSight replied to xtonyx's post in a topic in Classics
    I remember spending awhile finding ones that would fit and were meant for front and rear...they have them on http://www.jcwhitney.com/Street-Tires/GP_2...14323_10111.jcw now but I got mine from bike bandit ffor 56 and 60 each but I checked there and they dont have them anymore.
  10. BlindSight replied to BlindSight's post in a topic in Classics
    my dvom just got rained on and wont work anymore but do you think that could cause it? I mean after it dies and sits a min I can still use the electric start and it will crank over so I figured it wasn't battery/charging related.
  11. BlindSight replied to BlindSight's post in a topic in Classics
    Nope I havn't gotten any help...will be working on my bike later this week a little bit though. I was going to start by rebuilding the carbs but if it didn't fix your problems I might go ahead and replace the ignition coils and CDI and see if that makes a difference.
  12. BlindSight posted a post in a topic in Classics
    Ok so trying to figure out which carb kit I need to by for my 1980(what the title says) yamaha xs400 special (had special badging on the airbox cover panels originally).... I found some pretty cheap from partsnmore.com... but which one, is it the G model? Also, under the carb holders there is no G model but they do have an XS400S? https://www.partsnmore.com/cat_index.php?mo...p;category=carb
  13. BlindSight replied to xtonyx's post in a topic in Classics
    ill get the tire size for you later this week when I go visit my mom (bikes at her house right now). As long as its aligned properly there is maybe 1-2mm clearance on the swingarm in the rear.....bareeeeeeely fits but looks a million times better than stock IMO.
  14. BlindSight replied to BlindSight's post in a topic in Classics
    yeah I have already replaced most of the normal stuff and it had been sitting up for almost 2 years..will check the venting on the tank this weekend when im home but I cant ride it to work the kinks out when it dies every couple of mins
  15. BlindSight replied to xtonyx's post in a topic in Classics
    love the bike...I want to find a tank like yours...what did you use to cover all of the electricals? check out bikebandit.com for the whitewalls...I love mine although I cant fit any fenders (dont want to anyways but I noticed your running your front...it wont fit after these.)...here are some pics..still needs some work here and tehre but its close....bike is dirty and walls are filthy but you get the idea....
